Topic: Need help - black tank won't dump Posted: 14 Jul 2011 at 2:00pm |
kymooses, yup, filled to the top of the toilet valve. Even worse I noticed water dripping out from the cabinet under the sink and opened the door to find the connections to the sink drain were loose so with the black tank backed up into that pipe it was leaking. All over our plates, cups, foil, ziplock bags, etc. So my wife just handwashed everything outside and I just spent the last 1 1/2 hours messing with the tank. I had an idea to fill the gray water tank, then use that to fill the sewer hose, then close the gray valve and lift the hose up in the air to backwash into the black tank. I got some out but not much. Maybe enough to handle teeth brushing and a night time bathroom run. I think part of the problem is even though I have the risers my dump valve is barely higher than the sewer connection. I can't talk myself into disconnecting everything and going for a drive. Yet.
Fishtail, on mine there is the valve then a 90 degree bend to the hose connection. Maybe 4" total on the outside of the bend, 3" on the inside.
kymooses
Posted: 14 Jul 2011 at 3:37pm |
Very very sorry to hear about the latest bit with it. I'm not sure enough bleach exists in the world to steralize everything if something ever leaked inside.
Posted: 14 Jul 2011 at 4:26pm |
At least that water was 99.9% from the sink itself, probably nearly nothing from the tank down below!
kymooses
Posted: 14 Jul 2011 at 6:46pm |
CHEERS to that!
Outbound
Posted: 14 Jul 2011 at 7:15pm |
Doug, I'm confuzored!  When talking about water coming from under your sink, are you saying that your sink drains into your black tank? Mine drains into the gray tank, along with the shower.
And I won't ask how you managed to fill your 35 gallon black tank just using the toilet. But, maybe I've just answered my own question... it sounds like your sink does drain into the black tank. *****
Anyway, the Valterra knife valves are fairly simple, well made devices. A quick google search showed no complaints of Valterra valves failing. In fact, just the opposite: when electric or remote-cable valves fail, they're replaced with manual Valterra's like we have on our R-PODs.
I assume that everything feels fine when you pull the handle on the valve open and closed? I'm pretty sure that, if it was broken, it'd feel very different. So, I suspect that you've got a clog.
Best solution I've got is the obvious one: park the trailer somewhere where the ground can get messy. Put on a pair of rubber boots, gloves and old clothes. Grab something long, strong and flexible (like 3/4" PVC pipe), open your black valve and start poking up there like you're givin' the pod a prostate exam.
Once you've drained the tank, you'd better get your hand up in there to make sure you've pulled out everything that's clogging the valve... hopefully, its just a couple of paper towels.
Outbound
Posted: 14 Jul 2011 at 7:23pm |
Posted: 14 Jul 2011 at 10:01pm |
LOL! Love that movie. No Y connectors in my 'pod! I thought the sink went to the gray tank, too, but we haven't had a problem under the sink until now. I think some jurisdictions consider sink water to be black so maybe that is the reason. The valve doesn't feel any different than before, and now that I've shoved a stick up the pipe past the valve I know its open. My first solution is going to be to pack up a little early on Sunday and then go for a drive for 15 minutes, come back to my site and try to dump. If that is a no-go I have a 4-5 hour drive to my dealer when I leave here so that should slosh things around really good. I figure they must have a dump connection somewhere for when they have to work on tanks so I'll try to dump again when I get there. If they don't, well I guess its going to have to wait until I get it home. I really hope option 1 works, the thought of hauling 35 gallons of waste water to the dealer and then home is a real pisser.
Posted: 17 Jul 2011 at 6:29pm |
The 'pod has been dropped off at the dealer for a scheduled removal of the decals on the front and rear. I couldn't get the tank to dump at the campground even after driving it around and putting it up on all the blocks I had to get it higher and angled slightly towards the drain valve. I didn't see a dump connection at the dealer so I have no idea if sloshing around for several hours fixed the problem and won't until I get it home in a week or two. Its going to smell GOOD after baking in their lot in the sun!
kymooses
Posted: 17 Jul 2011 at 9:12pm |
Sorry mate, was really hoping to hear better news about that.
Hodge-PODge
Posted: 20 Jul 2011 at 9:06pm |
Well, Tech, you're bound to be an expert in this new topic by the time this stinking situation is resolved!
2011 RP 177, the Hodge-PODge
2011 Mercedes ML350
