r-pod gas mileage fix |
Post Reply | Page 12> |
semiretired
Newbie Joined: 16 Jan 2011 Online Status: Offline Posts: 1 |
Topic: r-pod gas mileage fix Posted: 17 Jan 2011 at 9:22am |
I am a new member who has not bought a r-pod yet. Looking over everybody likes and dislikes poor gas mileage towing seems to be the big complaint. Has anybody looked into the wind deflector kits that semi trucks use. Their are kits for mounting on the roof of a pick up or suv etc. What I have read the closest to the front of the trailer the better.In my case I have a fiberglass cap and it could be mounted to the rear of the camper cap. Has any one looked into this option. These deflectors are adjustable changing the angle for best results of air flow.
This deflector is suppose to give about 2 mpg increase. Cost about $350 Any input would be appreciated...thank you |
Posted: 17 Jan 2011 at 6:35pm |
Welcome. You have touched on the biggest discussion we've had around here. If you haven't read through it yet, you should look at this thread: http://www.rpod-owners.com/forum_posts.asp?TID=1347&title=gas-mileage Air dams have been mentioned as a possible fix, but I don't think anyone has done a before-after test to see if they help. One of the mods here found a slight increase in mpg when he put his kayaks on the roof of his tow vehicle in a V formation. |
rpodcamper.com
Admin Group - pHp Joined: 26 Nov 2009 Location: Reading, Pa Online Status: Offline Posts: 3990 |
Posted: 17 Jan 2011 at 9:49pm |
I have played around with different tow vehicles and combinations of items. i did find an increase when the kayaks were in a v shape on the top of my trail blazer. I'm now pulling with a dodge ram 1500 and looking to put a cap on it and the kayaks above it. Will let you know what I Find out. I don't think an air dam will do much and also if you look at the cost versus the savings you see you will have to tow a bunch of miles before the break even point
Goose
Posted: 18 Jan 2011 at 12:33am |
After reading up on trailer aerodynamics, one of the best ideas was to lower the front air dam under the front of the TV and then add side skirts along the sides to keep the air from flowing uder the TV. If you added side skirts along the frame of the POD from the hitch all the way to the back, you would force alot of air around the trailer. So much for axle risers though. The air conditioner on the roof creates some drag as I would have to believe that the spare tire set the way that it is creates some drag also. It was said that without the front air dam or side skirts keeping the ground clearance of the TV and the trailer the same would help. Keep the under side as smooth as possible. The greatest amount of drag comes from the turbulance between the TV and the trailer. If we could make the TV and trailer seamless that would end a lot of the problems.
Like rpodcamper says, those that only travel 300 to 500 miles a year the cost would not justify the savings. You would have to do the 2 to 3 thousand cross country trips. Goose
TIDALWAVE
Senior Member Joined: 21 Nov 2009 Location: MINNESOTA Online Status: Offline Posts: 315 |
Posted: 20 Jan 2011 at 9:05am |
When I ran some airflow simulations on the R-Pod and a couple of tow vehicles (see Fall, 2010
Forum) , not only did the separation distance between the Pod and the TV make a noticeable difference but also the disruption of the airflow caused by the 'relatively' large AC on the roof! I ran several other simulations using a different 'bread-box' profile and found more disruption caused by the AC than using a tear-drop profile versus 'an old fashion' squared off design. Some conclusions: the TV-RPod gap caused a noticeable disruption even when an airfoil was installed on the TVs roof (the Pod's curved front roof increased the gap compared to a squared off front section); the R-Pod's tear-drop profile did nearly nothing increasing airflow efficiency; the AC on the roof of the Pod made the most noticeable change in airflow (airfoils on the Pod's rear were mainly ineffective). |
TIDALWAVE
Goose
Posted: 20 Jan 2011 at 10:45am |
For the air conditioner on the roof of the POD I have thought of making an air sheild for the front and a boat tail for the rear, using fiberglass with foam to create the shape.
In the front I thought that a cover over the propane tank and battery following the v of the frame back to the front wall and angling upward slightly might help to reduce the turbulance between the TV and the POD. Keep it light.
I keep telling myself to get out to the garage and make a wind tunnel and scale models to test ideas on increasing efficency, but it has been to cold. Goose
Goose
Posted: 20 Jan 2011 at 11:15am |
TIDALWAVE, I went back and looked at your youtube sims. I had not seen those before and what got me was the amount of air disturbance that starts at the front of the TV and flows under it all the way to the rear of the POD. I am highly impressed with ability to do that, but I have to wonder what the difference would be if you added an air dam at the front of the TV along with side skirts. It looks like that may help a lot stop some of the drag. Goose
blissful
Groupie Joined: 17 Apr 2011 Location: Florida Online Status: Offline Posts: 53 |
Posted: 06 Jun 2011 at 7:14pm |
If you keep the speed under 50mph(which most people prefer not to bepoking along) it will increase your mileage...I own a 2006 Hyundai Tuscon and get 15mpg by keeping my speed around 40mph.
Blissful
Outbound
Posted: 06 Jun 2011 at 10:45pm |
The leading edge isn't nearly the problem that the trailing edge is. Have a look at the airflow simulations I did when I bought my R-POD. A spoiler will be far more effective than a deflector. Look around at the aftermarket manufacturers sites and you'll see that realistically, deflectors, spoilers or other approaches may increase gas mileage by 2-10%. This will take 10 MPG to an optimistic 11 MPG. This means you'd save 4.5 gallons of gas on a 500 mile round trip.
And lets say that you travel 5,000 miles per year with your R-POD. At 11 MPG vs 10 MPG, you'd save 45.5 gallons of gas. At $4/gal, that would be $182. How much are you willing to spend on deflectors or spoilers to achieve that savings? Keeping your tires properly inflated, your trailer properly levelled, your speed reasonable (55 MPH) and dramatically reducing jackrabbit starts are by far the most effective things you can do. They're free, too. With conservative driving on relatively level roads, you may achieve 13-13.5 MPG. At 13 MPG, that 5,000 mile annual distance would save you 115 gallons - $460 at $4/gal. And time-wise? That 500-mile round trip would take 1 hour and 24 minutes longer at 55 MPH as opposed to 65 MPH. Forty-two extra minutes each way.
Snowbound
Senior Member Joined: 17 Apr 2011 Location: Edmonton, AB Online Status: Offline Posts: 270 |
Posted: 07 Jun 2011 at 2:11pm |
Thanks Outbound. We appreciate you doing all the math!
Tom and Bette
in our 177 "The Gastropod" |
