  New Posts New Posts RSS Feed: Floor Repair
Floor Repair
 Post Reply Post Reply Page  <1 234
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Topic: Floor Repair
    Posted: 29 Jan 2024 at 10:29am
I drilled through the floor on our 179 a couple years ago and I recall it being fairly thick. It was over an inch for sure; may even have been 1-1/2". I didn't need the exact thickness for what I was doing, but I recall it being thicker than I expected.
You may just want to drill a test hole through someplace inconspicuous to get what you need. You can fill the hole with caulk.
cbardy58 View Drop Down
Post Options Post Options   Quote cbardy58 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 10:40am
The "subfloor" is a multi-layered/compressed/glued concoction of thin plywood (1/8"?) on interior (under vinyl flooring), exterior layer also being the same plywood with under belly material coating. Sandwiched between these layers is a 1 1/2" welded aluminum frame. Between the framing members are large pieces of foam that are cut to size. all these pieces are put together, glued and "pinch rolled" under 1600lb psi. The floor in an R-pod extends to the outside edge of the walls, meaning they provide wall support, also meaning they can be a real pain to work on.
Take a look at this construction video: https://www.youtube.com/watch?v=vMXneKc_fDo&t=120s
Thomasandrews628 View Drop Down
Post Options Post Options   Quote Thomasandrews628 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 10:52am
I have water damage along the back wall where the main bed is located,it's completely rotted out,so if I can remove all the damaged then just go back with 1/8 or 1/4 luan for my top layer?
TA
Post Options Post Options   Quote cbardy58 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 11:00am
First you have to fix the source of water damage, otherwise, fixing it is not going to be worth your time.
The plywood is glued right to the aluminum studs and the foam. When you demo the floor, you have to do so without damaging the foam.
Along the back wall there is an 1/8" plywood covering the wiring, etc. you should be able to remove that as it is not glues down, just stapled. take a look inside there to see how deep the water damage goes, though there is a piece of 2x2 (or close to it) for stapling the plywood covering.
pedwards2932 View Drop Down
Post Options Post Options   Quote pedwards2932 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2024 at 6:21pm
N/A
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2024 at 9:49am
That is why some of us have added those supports. I added one to our (former) RP-179 and it really helped.
My steps on the R-Pod were attached to the frame, not the floor. Do you have the MORryde steps? That is what we have in the Cherokee Grey Wolf we have now. Those do attach to the floor.
