  New Posts New Posts RSS Feed: Comment tv
Comment tv
Marian View Drop Down
Post Options Post Options   Quote Marian Quote  Post ReplyReply Direct Link To This Post Topic: Comment tv
    Posted: 16 Aug 2022 at 10:50am
Our comment tv will not scan either cable or air channels. Has anyone else had this problem.?   how did you get it fixed. I sure would appreciate your help. Thank you.
Pod People View Drop Down
Post Options Post Options   Quote Pod People Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2022 at 6:04pm
I don't know what type of tv you have.  Make sure the antenna booster switch is turned on.  It is a small push button generally on a cover plate near the cable/tv connection.  Push it in and there should be a little red light alerting you that it is on.  Hopefully that will solve your problem.
Make sure to turn it off when finished or it can run down the battery if you are not hooked to shore power.It will be a constant drain on the battery when turned on.
Travel safe and often
Vann
Vann & Laura 2015 RPod 179
