Comment tv
Forum Name: I need HELP!!!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=15431
Printed Date: 08 Jun 2025 at 7:20am
Topic: Comment tv
Posted By: Marian
Subject: Comment tv
Date Posted: 16 Aug 2022 at 10:50am
Our comment tv will not scan either cable or air channels. Has anyone else had this problem.?   how did you get it fixed. I sure would appreciate your help. Thank you.
Posted By: Pod People
Date Posted: 16 Aug 2022 at 6:04pm
I don't know what type of tv you have.  Make sure the antenna booster switch is turned on.  It is a small push button generally on a cover plate near the cable/tv connection.  Push it in and there should be a little red light alerting you that it is on.  Hopefully that will solve your problem.
Make sure to turn it off when finished or it can run down the battery if you are not hooked to shore power.It will be a constant drain on the battery when turned on.
Travel safe and often
Vann
Vann & Laura 2015 RPod 179
https://postimg.cc/0zwKrfB9">
