EscaPOD Adventures - 2022 edition |
Page <1234> |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6437 |
![]() ![]() ![]() ![]() Posted: 15 Jun 2022 at 11:42am |
I can't argue with you there. I would not have thought of the frame bending. I agree that the frame is not adequate. However, until there is enough pressure on manufacturers to change, they won't.
I will report this to the NHTSB. It does look as if the axle bent again, but I will take measurements later, when it cools off somewhat outside. It is too hot right now to be doing that sort of thing.
But StephenH, your TV frame went over the same surface and didn't get damaged did it? And many others have reported bent axles, frames, damaged floors, slide structures, etc. You've had a bent axle already too IIRC?
My point being that lower end travel trailers like rpods are just not designed with adequate structural safety margins. They aren't required to, and consumers are apparently willing to tolerate damage to their trailers that would be unacceptable in their other vehicles. The tongue and tongue to frane attachment does not see as high loading as the frame in the axle attachment area does, so it shouldn't be surprising that your frame failed where it did. That's because the moment due to the load at the rear of the trailer pushing down is combined with that from the torsion axle rotating upwards. |
This was anything but normal use. We pulled off the road onto an area that looked like it had been graded only to find out that it was very rutted and we were bouncing quite a bit. I think the only reason the A frame did not bend also was because the trailer tray hit up against the front of the RPod (I can see the marks) and kept it from flexing more than it did.
Linda&Gino ![]() Newbie ![]() ![]() Joined: 04 Jun 2017 Location: New Mexico Online Status: Offline Posts: 32 |
Ditto on finding a shop. I have read where some shops aren't taking RVs over a few years old because they are overwhelmed by warranty work and can't find workers.
The whole bent frame thing has me shaking my head. Having spent years working in and owning a motorcycle shop, bent frames where something you would expect from either a serious crash or from an inferior brand like something from China. To have a frame bend from "normal" use blows my mind.
gpokluda
2017 Rpod R179 SOLD! 2022 Escape 5.0 TA 2022 Ford F150 4X4 EB3.5 Triumph T120 Bonneville |
Not sure about the axle. Once the frame is straightened, then I will be able to tell about the axle better. Andrew thought it did not look bad. I also want to look at the tires for any unusual wear. They have a couple of thousand miles on them from Utah to Arizona to home.
Glad you found a shop you like that was willing to take in the work. Did you end up deciding the axle camber was ok or are you having to get that recambered?
I towed our EscaPOD to Littleton, NC yesterday. Today, the frame should be straightened and reinforced. The person recommended was Andrew Smiley. He will be welding plates to the frame on the bottom behind the riser and on the side on the outside of the frame. This is in addition to welding the crack on the driver's side.
The best thing is that the cost of repair should be much less than I was expecting. I will still relay the information to Lippert, but I'm not going to try to file with insurance since that would likely lead to higher rates so paying the cost out of pocket is likely a better option.
Monday the trailer will be looked at and I will have a better idea of what it will take to repair it. I know some welding will be involved as I see a crack in the frame on the slide side. The good thing is that it looked to be pretty stable and did not expand any on the way home, even when we did hit some rough roads.
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 399 |
Keep us posted on what they decide to do. Thanks for the updates.
Gpokluda
Okay. We made it home without further incident. I did take the advice and put the spare in the back of the truck and rearranged things to make the load on the back end of the RPod as light as possible. Now that I am home, I will set up an appointment to get it checked out and repaired. Hopefully, part of the repair will be to add some strengthening to the frame so it will be less likely to bend in the future.
Page <1234> |
