  New Posts New Posts RSS Feed: r-pod 196 Wheel Camber
  FAQ FAQ  Forum Search Search  Calendar Calendar  Register Register  Login Login
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Topic: r-pod 196 Wheel Camber
    Posted: 30 Nov 2021 at 3:59pm
To be more clear, there is a safety
built into the axle rating. I don't know what it is for the 196, but when I did the math for the 179 a few years ago I came up with a safety factor of a bit less than 2x, so a 3500 lb rated 179 axle can handle around 7000 lbs before failing.
That means that the axle could fail with about a 2 g bump load on it. That's not enough to handle bumps and potholes. Hence the common issue of bent axles on the 179's.
Since you have a 196 YMMV but the general concept is the same.
