Outriggers Forest River parts |
Post Reply | Page <1 34567 13> |
pedwards2932
Senior Member Joined: 21 Sep 2020 Online Status: Offline Posts: 338 |
Topic: Outriggers Forest River parts Posted: 14 Sep 2021 at 1:42pm |
Coming in on the tail of this but I think some of my issues at the front of my rPOD were due to not enough support. I am going to order 8 of these and use 4 on each side. Does that seem reasonable? I was going to make sure 2 where the pullout is. I was going to try to evenly space them for all the others.
PilotPodder
Post Options Quote Reply Posted: 14 Sep 2021 at 5:43am |
John, there are a few outriggers on the frame. The slide is unsupported. There is an outrigger near the front of the frame and then nothing for 9' until the next outrigger near the axle. Glad the floor support video was helpful. There was a lot of pain involved in getting that work done by FR and I am very happy that the solution has helped others.
JA-Pod
Newbie Joined: 28 May 2019 Location: Raleigh NC Online Status: Offline Posts: 35 |
Post Options Quote Reply Posted: 13 Sep 2021 at 8:42pm |
Not too bad of a mod to perform, although the sag is concerning in that you will have to jack up the slide, others have done it successfully, I fortunately did not have to do that, also you mention in your first post that you have no outriggers for 9 ft, did your 2017.5 come with outriggers?, unless I misunderstood your posting.
thanks John for all of your videos, most helpful especially when I picked up our pod 2+ years ago, we knew nothing of the travel trailer and specifically the pod world. I was able to use your advice to fabricate a support beam under the kitchen floor, it has really help to shore up the floor. cheers john
John & Allison
R-Pod 179 (2017) Nissan Frontier SL V6 4.0 (2019) |
PilotPodder
Post Options Quote Reply Posted: 13 Sep 2021 at 9:10am |
Quick update on purchasing the outriggers for the R-Pod 179, as of 9/13/21 a.m...
I contacted Jenn Weldy at FR (R-Pod Parts) via email (jweldy@forestriverinc.com) with the part number (F100140948 FORMED OUTRIGGER - 4A) and she got back to me pretty much immediately with confirmation that the part is still available. I was instructed to call her to complete the order, which I just did. I purchased 8 units to facilitate potentially adding them to both sides of the trailer. ~PP
PilotPodder
Post Options Quote Reply Posted: 12 Sep 2021 at 3:12pm |
Late to the party unfortunately. Just discovered sagging at the slide-side of my 179 last week when my slide snagged the ottoman when bringing it in. Obvious wall sag below the slide outside and no outriggers for roughly 9' on my 2017.5. Glad to find this thread and great info. Likely I'll put a video out on the fix at some point and may hit some of you up on for more info along the way. I am very glad for this forum!~PP
LB Boozer
Newbie Joined: 18 Feb 2021 Location: Long Beach, Ca Online Status: Offline Posts: 25 |
Post Options Quote Reply Posted: 17 May 2021 at 11:09am |
I too received my outriggers (without mounting hardware) from FR last week and installed one set on the drivers side under the slide and 3 on the passenger side. I only had one area that was sagging very mildly and also used a bottle jack to get it square. I used 1" self tapping screws for the areas where the tank was in the way and 3/8' through bolts, with 2" washers, lock washers and locking bolts (all ss). Took a little while as my pod is off center to the frame so I had to trim and drill new holes for the drivers side outriggers and I trimmed all the aluminum c-channels under to get a nice flush mount. Hopefully this prevents future issues.
Post Options Quote Reply Posted: 17 May 2021 at 10:54am |
I'd add flat washers too, spreads the load on the frame tubes. Through bolts are a better solution than self tappers because the dang frame tubes are so dang thin. I think the self tappers are only 14 threads per inch and the tubes are 0.1 inch so that's only 1.4 threads engaged in each tube wall. Not much.
Put the outriggers anywhere you suspect or are concerned you might get sag. Sag has been reported in other areas besides the slide area. Won't hurt anything. I'd just place a shim rather than cut the channel. Why weaken another part of the trailer? |
JA-Pod
Post Options Quote Reply Posted: 17 May 2021 at 9:32am |
I too ordered and received a new set of outriggers to be installed on the door side of the rig, mine came this time without any bolts, screws unlike the last batch where i received TEK screws, no worries since I will bolt these through with 1/4 in bolts with lock washers and nuts. I will review again if I need to cut the channel, possibly add a shim to take up the space of the channels thickness (1/8 inch?) will see if this will true up to where the frame and floor corner meet. thanks all for the inspiration to proceed with the other side of the pod, did not know others were experiencing issues with that sag. As far as the slide out side, i only installed them under the slide, do you suggest that they also should be installed along the frame away from the slide area?
John & Allison
Post Options Quote Reply Posted: 17 May 2021 at 8:40am |
When the package with mine arrived, it was split open on the bottom and there was no hardware bag inside, just the four brackets. I did not want to wait on FR sending replacements, so I got the hardware locally to attach two of them to supplement my homemade ones. I am considering adding the other two to the door side.
Post Options Quote Reply Posted: 17 May 2021 at 8:00am |
Ah, my bad. Should have looked at the photo of the bag.
