enolte ![]() Newbie ![]() Joined: 11 Mar 2015 Online Status: Offline Posts: 3 |
![]() Posted: 28 Feb 2021 at 5:02pm |
Help. Got the husband to run a dedicated to plug for the 171. Mission was to just charge battery. With the 30 amp breaker on in the camper it throws our 20 amp. With 30 amp (main) off all is good....but here is my dumb question.. am I charging the battery? And - if I want lights to be on “shore” line is there a modification that can be done to the camper box to have a 20 amp alternative?
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6422 |
Unless you are trying to run the AC and the water heater, there is no way the RPod should be tripping a 20A breaker. Make sure the switch for the water heater is off. If it is tripping on that breaker, and is not tripping when plugged into shore power at an RV park, then I suspect that the polarity of the outlet is reversed. I don't know for sure if that is the case, but before I installed the 30A RV outlet, I plugged our RPod into a regular 15A outlet. As long as I did not try to run the big appliances (AC, Microwave, Water Heater), I had no issues. That is why I expect something is amiss with the outlet and not with the RPod.
+1 to SH, I run my Pod on a 15A circuit all winter long t charge battery and have lights, nothing high amp. Need to check the connection.
Yep something is wrong. I can run my a/c on a 20 amp breaker no problem. Everything else will run in 15A. As StephenH suggests, be sure all the loads in the trailer are turned off, including the water heater and a/c. If your home breaker still trips then run an extension cord from the trailer to another receptacle in the house. 15 amps will do. If that doesn’t trip then the new receptacle you just put in is miswired. If it still trips then you most likely have a short in the trailer somewhere. Turn all the trailer breakers off and then switch on one breaker at a time to find out what is causing it.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2707 |
+1.
Something wrong there. We have our Rpod on a 15 amp breaker when we're at home. If the battery is charged up, we've also been able to run the A/C.
Thank you all! Husband now has some good troubleshooting bullets.
Please update us when you find the answer.
TimK182G ![]() Groupie ![]() ![]() Joined: 12 May 2020 Location: Hopkinton, MA Online Status: Offline Posts: 46 |
I as well only trip the 20 amp breaker if I run my A/C for an extended period during extreme heat. Otherwise, no issues at all. I redid my garage and part of the remodel was a dedicated 30 amp breaker with the correct 30 amp outlet mounted outside. Almost done, can't wait to use it this year.
2018 R-Pod 182G
2014 GMC Sierra 1500 |
