  New Posts New Posts RSS Feed: Battery charger - equalization
Topic ClosedBattery charger - equalization
Olddawgsrule View Drop Down
Direct Link To This Post Topic: Battery charger - equalization
    Posted: 20 Feb 2021 at 7:19am
CTU, I didn't find a requirement for equalization of my dual 6v's. Charging in series mode, like they are in the camper, does it fine. Of course this is when they are bought together, one old and one new will only produce according to th weaker of the two.
I am a proponent for the batteries to stay in use and go through C/D cycles. I use a 2a trickle charger and an array of LED lighting that's +/_ 1a to draw the battery a bit. I'd go about a week on the draw, charge back up (slowly), let it rest a week and start the process again.
My last set went me 18yrs. Watch your water levels, do mild draws not >50% (I typically draw only to 65-70%) and they will last.
Safe Travels!
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 19 Feb 2021 at 6:59pm
+1 to StephenH
What I have done here in northern Michigan is to use a simple 2 amp trickle charger.  Each battery is charged for 24-36 hours in early November and then sit in 'hibernation mode' (unhooked from charger) on a concrete floor in a unheated garage.  Just checked them a week ago and the voltmeter shows 12.82 and 12.65 volts.  I will give them another 2 amp trickle charge in early May before getting re-installed in the 177.  These batteries are 12v Interstate group size 24 deep cycles that will be 10 years old next month.  Pretty reliable.
Camp town usa View Drop Down
Direct Link To This Post Posted: 19 Feb 2021 at 6:15pm
Unit is in unaccessible storage and batteries are stored in basement for winters.  That said, I will need to maintain the batteries each winter, so would like to get something which will last and treat the new batteries well - being able to charge and EQ.  I plan to plug to house line during season via dogbone or solar suitcase in the driveway.
Direct Link To This Post Posted: 19 Feb 2021 at 6:00pm
You do have a charger. It is in the converter and is programmed to properly charge flooded lead-acid batteries. The only time you would need a separate charger is if you remove the batteries during the winter. If you can leave them in and the RPod connected to shore power, the converter will maintain the batteries just fine.
Direct Link To This Post Posted: 19 Feb 2021 at 3:29pm
I recently purchased a set of Trojan T105s but dont have a charger for them yet.  Im trying to find a charger which will accommodate equalization mode.  I am having a hard time finding best approach to make sure they are charged and when needed i am able to perform EQ.  There is seemingly fine print on a lot of chargers out there on what they do.  What is suggested option?
