Topic: Ball Mount Question Posted: 22 Nov 2020 at 2:05pm |
I use adjustable "stingers" as I tow several things and would rather adjust height of hitch then change stinger every time. It's ok the stinger is rated higher than your hitch or capacity. For towing I recommend level or a bit low in front. Not more than 2 inches. The receiver and ball size is 2 inches. I'm a fan of the Tekonsha contollers, while there are many good ones. I still have a vehicle with a P2, I sold the truck that had a P3 in it. Lot of places you can buy ball mounts, we have a local Tractor Supply which has an excellent selection. My last adjustable ball mount came from etrailer.com as did all my controllers. Best about etrailer is the have a customer service line that will answer any question you have.
Posted: 22 Nov 2020 at 1:17pm |
I'm pretty sure the 2" drop/ 1" rise means if you install it one way you have a 2" drop, but if you turn it over (and install the ball from the other direction) you have a 1" rise.
It's nice to get things as close to right as you can, but remember, when you put the weight of the Pod down on the ball, the back end of your truck is probably going to go down a bit.
Posted: 22 Nov 2020 at 12:37pm |
Go with a 1" - 2" drop (front of pod lower than rear) when towing. Reduces potential of sway. Ideally you also want 10% - 12% trailer weight on your receiver, again to reduce potential of sway.
mjlrpod
Posted: 22 Nov 2020 at 12:30pm |
Having a stronger ball is never going to be a bad move. So If cost is similar, I say go for it. As far as brake controller, I use the tekonsha P3 which is a great controller, and will probably plug and play in your vehicle. As far as height, it's better to be a little lower, than being higher. If it's a little low, it will push down on the back end if you brake aggressively, helping you have better stopping traction. Being a little high would tend to lift the back end.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Dirt Sifter
Posted: 22 Nov 2020 at 12:29pm |
This is the brand of brake controller I had installed on my Tacoma; it is posted on the Forest River forums' classified section.
https://www.forestriverforums.com/forums/f246/new-never-used-tekonsha-p3-brake-controller-220715.html I have used a 2" drop WDH for our 195, but used a straight 2" ball and hitch when we had a 179. We used sway control with both hitches. Really not too concerned about 3/4" difference as long as the hitch weight was right. Others will be able to express more grounded opinions on this issue for sure. The Rpods are so much fun; good choice.
Greg n Deb 2020 195 HRE
john in idaho
Posted: 22 Nov 2020 at 12:24pm |
I seem to have accumulated a collection of various heights of "Stingers" - that is what the part that slides into the 2" receiver is called" - over the years. The majority came from U-Haul so they may have a bigger selection than Walmart, and perhaps a more know legible person to ask. Just a suggestion ....
EchoGale
Posted: 22 Nov 2020 at 10:43am |
hi there... I'll leave the calculation question to others as I'd be guessing but I wanted to say that I bought Curt's Bluetooth brake controller this summer and I'm really happy with it. The device cost most than others but the install was way less so they ended up about the same.
Welcome...I hope you love your pod as much as I love mine. Julie
Julie
SkeeterPod11
Posted: 22 Nov 2020 at 10:30am |
Hi Everybody,
So im looking to get a ball mount hitch for my 2021 Toyota Tacoma SX. I measured to the top in the inside of the hitch receiver and got 18.5 in. Then measure to the bottom of my cupler of my Rpod 180 and got 17.75 in. Getting a difference of -.75. If im correct in my understanding of how you calculate this, I need a drop of 1in. I went to Walmart and could only find hitches with 2in drop and higher. Now I notice some have drops and rises on the same hitch. If I got one with a 2in drop and 1 in rise, would that give me what I need..? I also believe I need a 2in ball. In addition, the one I was looking at was class V. & is certified for up to 17,000 lbs. thats much more then my TT which is about 3,700 loaded. Is it safer to get a stronger hitch the needed or is it not necessary. I also would love any insight on a good brake controller to go with as I will be needing to get one as well, Im newer to towing so something that is user friendly would be best. Thanks you your time.
