Page <1234> |
Author | ||
![]() Posted: 16 Oct 2020 at 12:29pm |
For FR to reasonably claim a hidden plumbing leak was discoverable in a pressure test a normal human needs first know there is a test that needs to be performed and also needs to be able to follow the test instructions and identify that there is a leak. None of that is in the manual that I could find.
Here is the manual from their website for rpod models 2015 and newer. I don't see anything about a monthly pressure test, only a vague reference that you should suspect a leak if the pump "is running" when the faucets are off. That is certainly not a scheduled maintenance inspection and requires you to be dry camping and to interpret what "is running" means. For how long and how often? My pump turns on every once in awhile for a short time either from a slightly leaky pump check valve or a slowly dripping faucet. I doubt it would run more for a tiny pinhole leak from a staple. Many folks always camp with city water and never use their water pumps. Then under monthly maintenance it says "check hoses, fittings, and connections for leaks and wear". That clearly reads like a visual inspection, nothing about running the pump for a pressure test. |
sawyernlsn44 ![]() Newbie ![]() Joined: 26 Sep 2020 Online Status: Offline Posts: 13 |
Exactly! Were any of my fellow r-Pod owners instructed to do monthly pressure tests and taught how to do it? They're making things up as they go. |
2018 r-pod 180
2017 Volvo XC90 |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Online Posts: 6440 |
I did a bit of looking, and it seems that we would need to take it to a service place to have the testing done. The connector that is needed is either out of stock at the major retailers. If it is available, it is in the $85 range for a simple plug with a deep enough end to hold the check valve open. Look up JR Products 04-62275 and you will see what I mean.
Thanks for doing that research. At this point I'm going to keep pushing it and make as many people aware as possible. It would be one thing if they were denying me because I'm not the original owner etc... If that was the reason, I would have just fixed the PEX and moved on with my life. But they're saying they're denying it because of a procedure all of us R-pod owners are supposed to be doing every trip that apparantly no one knows about. People need to see this so they know what customer service they can expect when spending thousands on a Forest River product.
2018 r-pod 180
2017 Volvo XC90 |
Where in the manual does FR specify that? |
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Online Posts: 3354 |
+1 Also looked in my manual from 2011 found NOTHING.
Another Forest River failure....and so many here defend Forest River while I lay it on the line:
Forest River customer service sucks. I found this out about a week into the ownership of my r-pod.
I don't disagree. That staple likely was in the line firm enough to plug the hole when it was pressure tested at the factory. I would contact them back and ask where in any instructions that they have provided to the owners that it states that the owner is responsible to have the water system pressure tested. The manual entry quoted says nothing about pressure testing. I would pursue this a little farther if you have the time and inclination. You could also contact the previous owner and negotiate something since he sold you a trailer that was supposed to not have any flaws.
I agree, this should be pursued with FR if you have the stamina for it. They are painting themselves in a corner by claiming that their customers should be doing monthly plumbing pressure tests. No reasonable person would interpret their manual that way. If they then revert back to denying you because you are not the original purchaser then they are not demonstrating a good faith effort to resolve what is obviously a latent defect that has been there since manufacture of their unit.
I completely agree with everyone and am absolutely going to pursue this further. Because if they're really going to tell me we should all be doing a pressure test before every trip, then they absolutely have to specify that in the manual and provide instructions. I'm going to make sure I get this out there. If anything to at least make people aware that if they're not doing a pressure test every trip, as I was told, Forest River can deny their warranty. I've already contacted the BBB and my local news channel's consumer advocacy department. I've also posted it all over social media. If anyone has other ideas please let me know. Thanks again for everyone's responses!
2018 r-pod 180
2017 Volvo XC90 |
Page <1234> |
