  New Posts New Posts RSS Feed: flushing out the antifreeze
Topic Closedflushing out the antifreeze
Hawkeyes View Drop Down
Direct Link To This Post Topic: flushing out the antifreeze
    Posted: 21 Feb 2011 at 3:30pm
I am so glad you are asking (and getting answered) these questions.  I think we are a month away from de winterize.  Dr Drew, are you in Northern or Southern Missouri?
Hawkpod
2013 Surveyor Sport 189
2017 Chevy Silverado
drdrew View Drop Down
Direct Link To This Post Posted: 21 Feb 2011 at 4:44pm
i'm thinking about 3 weeks.  i am in central missouri.  columbia.
172T
Direct Link To This Post Posted: 22 Feb 2011 at 8:38pm
The valve near the water pump should only be turned to the "antifreeze" setting while doing the winterization, after that you should turn it back.  It won't hurt if you leave it on the "antifreeze" setting, but if you don't turn it back then in the spring you'll wonder why you are getting almost no pressure in the water system.  Like I did last spring.  Embarrassed
Direct Link To This Post Posted: 23 Feb 2011 at 9:39am
hey tech can you tell me where to find that valve?
172T
TIDALWAVE View Drop Down
Direct Link To This Post Posted: 23 Feb 2011 at 10:16am
Somewhere near the pump there should be a hose with an open 'dead-end' It is connected to the main pump hose with a T-fitting valve. If you turn the valve in one direction, the pump will pull water from the water tank, turn it in the other direction and the pump will suck air through the 'antifreeze' hose because you don't have the open end of the hose stuck into an RV antifreeze bottle.
TIDALWAVE
Direct Link To This Post Posted: 23 Feb 2011 at 10:58am
thanks
172T
Direct Link To This Post Posted: 13 Mar 2011 at 4:49pm
For those interested in the172t i found it behind a panel under that stove cabinet nearest the floor. Had to remove 2 square head screws. I replaced the screws with a velcro system for easier access in the future.
172T
