Page <123> |
![]() Posted: 22 Aug 2020 at 6:11pm |
I clicked on that link hoping to learn something... but for me, the article is un-readable...over and over again they keep referring to 'dual axles'....
In the topic and world of transportation, trailers, and the like: duals are side-by-side wheels, but axles, one in front of the other, are tandems.
I just cant take an author (who is being paid to write this stuff) seriously enough to read their words if they can't go the effort to even get the basics right. It's like calling the fuel tank on a diesel truck, the 'gas tank'...or calling the main rotor on a helicopter, the 'propeller'... ARRGHH! |
Marketers doing photo shoots can stage anything anywhere. With all due respect StephenH, that article is worthless. The authors are towing a geoPro 19 FBS which has an dry weight of 3075 lbs and a GW of 4400 with a Jeep with a 3500 lb tow capacity. In my opinion they are an accident waiting to happen and are either idiots or worse are shilling for FR in a way that puts others at risk. I wouldn't believe a word they say. If anyone is considering a GeoPro or a NoBo for actual rough road boondocking use they should take a very close look at its wheels, tires, axle(s), frame, floor, and interior construction. Not saying that a NoBo or GeoPro can't go offroad, just that you can't assume it can just because FR markets it that way. Caveat emptor, you get what your pay for, etc....
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6428 |
Some of the pictures of the NoBo trailers show them in off-road situations. The ground clearance is definitely higher than that of the RPods. This may help: |
Has anyone inspected the structure of the NoBo trailers? I wouldn't assume that its significantly more robust than the rPod line without taking a close look. FR is clearly very conscious of image and rather less of substance, so it could be for show. There are purpose built off road trailers from other builders. As for the axle reinforcement, unless there were many trailers on the road with reinforced axles and none of them failed you really can't know statistically that it helps. I'm certain that it helps because the structural analysis says it does. Structural engineers build bridges and buildings all the time based on those calcs, if its good enough for them.... |
The NoBo (No Boundaries) line would be more suited to your purposes. I also did the axle reinforcement. You can find it in my mods. I did a pretty good write-up on how I did the modification. I am pretty sure it has helped.
I have an axle riser kit and removed the tongue jack and the rear stabilizer jacks, giving me a lot of ground clearance and possibility for articulation, and despite my best judgement, I took my 171 on some very nasty trails last year...trust me, the way the r-pod bucks and shakes and bounces and wiggles, I never wanna do that again. Crap inside was scattered and tossed all over. Cabinet doors were open and hinges were bent and busted. Everything in the fridge was tossed, shaken, mixed, broken, busted, spilled, and stirred. I did not plan on doing it that time, but other campers leading the way had assured me it was doable. Note to self: Walk the trail first next time! "Right tool for the job" sir, and the r-pod aint the right tool for that job. It just isn't. I'm pretty sure you plan on ignoring this advice, I can tell by your post. So...I'll volunteer to "hold your beer and watch this!" NEXT!
I would be cautious about lifting the trailer higher than the lift kit already does.
A couple of reasons: it will raise the center of gravity which will increase the tendency for the trailer to sway. It will also increase the load on the trailer frame at the axle attachment location. If you hit a bump there is a lever action trying to push the wheels up and backward which has to be resisted by the frame which gets pushed up at the back of the riser bracket and down at the front. There is at least one known case where a frame has been bent at that point, it is only a 4x2x0,1 inch tube and pretty marginal for the loads it has to carry to start with. If you do lift it I would suggest reinforcing the frame at the same time.
Also, if you lift the pod you will increase the frontal area of your rig and reduce your fuel economy, assuming you care about that. The other question I have is why do you want to lift? Rpods are not off road capable, they aren't designed for that. At the most, I take mine on improved forest service roads and when I encounter pot holes I can't drive around I crawl through them at much less than walking speed. I have 15 inch wheels and the lift kit and I've never once bottomed out. If you want to do real off road travel there are trailers designed for that purpose that are going to hold up much better than a lightly constructed rPod will. I have a thread on my axle reinforcement that posted in the first half of 2019 IIRC, you can use the advanced search to find it. If you can't find it let me know. I used a piece of 3x3 inch steel angle slightly shorter than the axle, had it bent up slightly in the center, and attached it to the bottom of the axle using 2 square ubolts placed as far outboard as possible at each end. My approach requires no welding, others have come up with different solutions. |
Scottalot ![]() Newbie ![]() Joined: 10 Feb 2019 Location: California Online Status: Offline Posts: 3 |
I would really like to lift my 179 to be able to get into more off-road places and I have thought of several different things - taller spacers (I already have the Hood River edition), larger wheels, maybe even air bags. Ideally, it would be great to keep it low for highway driving and then be able to pump it up when going off road. I am not sure what can be done with the stock axle and I fear it could be cost prohibitive to replace the axle...although it could be the only way to also get larger wheels with larger than 15" rims. Any and all thoughts welcome. Oh, and, offgrid, how did you reinforce you axle?
If you can't get in on the Costco deal, this is the one I purchased. I am very happy with it.
PilotPodder ![]() Senior Member ![]() ![]() Joined: 04 May 2016 Location: Portage, MI Online Status: Offline Posts: 305 |
FYI on this as Costco has a deal for members on Lion Energy Safari UT1300 Lithium batteries. $749 for one, $1400 for two. Seems like a reasonable deal given the Lion Energy site has these listed at $999 ea.
https://www.costco.com/lion-energy-safari-ut1300.product.100535965.html |
Page <123> |
