  New Posts New Posts RSS Feed: Kitchen sink separated from countertop
Topic ClosedKitchen sink separated from countertop
JPEG Pod View Drop Down
Direct Link To This Post Topic: Kitchen sink separated from countertop
    Posted: 04 Aug 2020 at 10:34am
Thanks Stephen H. We had a discussion with the dealer and it sounds like he’ll be willing to go the extra mile and install the top mount sink. Will see...
In the meantime will search for Lexel along our route this morning.
Thanks much!
Direct Link To This Post Posted: 04 Aug 2020 at 10:18am
It might be possible for the dealer to install the newer top-mount round sink shown in the first image, but I think the dealer would just reinstall the undermount sink and call it a day. There should be sealant around the lip of the undermount sink, both to keep moisture out and to help it to stay in place. If there is none, I would recommend something like Lexel which is water resistant (not for use in prolonged submersion though). Since that seam is unlikely to have prolonged submersion, it should work quite well. Unlike silicone, it is paintable.
Direct Link To This Post Posted: 04 Aug 2020 at 9:39am
Thanks but ours is the undercounter round model posted by another member. I appreciate your response though!
Direct Link To This Post Posted: 04 Aug 2020 at 9:37am
So obviously, the dealer should be able to replace ours with this top mount edition!
Direct Link To This Post Posted: 04 Aug 2020 at 9:35am
Our sink is the undercounter large round sink in the second image.
Pod People View Drop Down
Direct Link To This Post Posted: 03 Aug 2020 at 4:13pm
Many podders have replaced the undermount sink with a drop in model.  Elkay and Delta both make a single bowl bar sink that will fit in most cases. It does require enlarging the countertop cutout and repiping the supply and drain lines. I did ours and replaced the cheap faucet at the same time. It is much better.
good luck
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 03 Aug 2020 at 11:10am
Originally posted by JPEG Pod
Thanks for the heads up. 😢 It’s too bad tho, my sink is so pretty!  🙏
Pretty is a s pretty does.....
Please let us know what FR is willing to do for you.
Any bets on whether or not FR will want to just tack the sink back up there and let the warranty time out?
Pod_Geek View Drop Down
Direct Link To This Post Posted: 03 Aug 2020 at 11:03am
Interesting.  Our 195 has this sink:
Your sink?  (From older 195 walk-through video)
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
Direct Link To This Post Posted: 03 Aug 2020 at 10:51am
Thanks for the heads up. 😢 It’s too bad tho, my sink is so pretty! No wonder it won’t last. 😢 Love your flow chart and so glad we have duct tape on hand. Of course I packed everything BUT a new kitchen sink, so we’ll be using paper plates for a week. This is only the 6th time we’ve used our unit and it’s still under warranty. That’s the good news. Thanks again. 🙏
Direct Link To This Post Posted: 03 Aug 2020 at 10:10am
Very common problem with the newer under counter sinks. Bad design, bad execution. Screws in particle board - bad. Water penetration into board edges - bad. Fighting gravity - bad.
Best fix: remove the sink and install a drop in sink.
Less good fix: larger screws and washers, but don't expect that to be a lasting fix.
I love the duct tape temporary fix.
