  New Posts New Posts RSS Feed: TVs and antenna
Topic ClosedTVs and antenna
paddlewhisp View Drop Down
Direct Link To This Post Topic: TVs and antenna
    Posted: 22 Jul 2020 at 4:46pm
Hi Y’all,  I’m the new owner of a 2019 R-Pod 189.  I just love it...   but can’t get either tv to pick up local channels.  Any suggestions will be appreciated.
Paddlewhisp
Direct Link To This Post Posted: 22 Jul 2020 at 4:55pm
I have a 2015, I have to be in a location to receive channels, I have to do a search each time I relocate and I have to have my amplifier on. That's for me.
Direct Link To This Post Posted: 22 Jul 2020 at 5:37pm
+1 on making sure the amplifier is on and scanning for channels in every new location. It is not automatic.
Direct Link To This Post Posted: 22 Jul 2020 at 6:58pm
Thanks
Paddlewhisp
mjlrpod View Drop Down
Direct Link To This Post Posted: 23 Jul 2020 at 9:54am
Hopefully you know where the booster button is. It should be switched on (pushed in) and the red light is lit, to either watch t.v. or listen to the radio. Make sure you switch it off when your done, it will kill the battery.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 23 Jul 2020 at 10:01am
With the radio we have, I have not needed to have the booster on to listen to the radio in our 2016 RP179. Perhaps the newer units are different though.
podwerkz View Drop Down
Direct Link To This Post Posted: 23 Jul 2020 at 10:13am
If that is the case you need a new battery or a better charging system. The TV pre-amp does not use much power. In fact the propane detector uses more power than the TV pre-amp.
Direct Link To This Post Posted: 23 Jul 2020 at 2:25pm
Hubby and I just spent several hours working on tvs and lack of signals..  nothing helps.
He took the box loose and it appears to be hooked up, but is acting like it has no antenna..
Is there a wiring diagram or manual on the antenna?
Paddlewhisp
Direct Link To This Post Posted: 23 Jul 2020 at 3:50pm
Do you have the Jensen television and entertainment unit or is your radio the Furrion unit?
Direct Link To This Post Posted: 23 Jul 2020 at 4:57pm
Would help to know antenna type.
