Weight Distribution hitch |
Page <1234> |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6422 |
![]() ![]() ![]() ![]() Posted: 30 May 2020 at 10:12pm |
Equal-i-zer's torque specification are: The hitch ball is 430 ft-lbs. The shank bolts are 320 ft-lbs. The sway bracket assemblies are 75 ft-lbs. See the Equal-i-zer site for details.
Toyanvil ![]() Senior Member ![]() Joined: 15 Feb 2019 Location: Bakersfield Online Status: Offline Posts: 157 |
I will bring up the down side of Weight Distribution Hitch's used on Rpods, since no one else did. Rpods are known for axles bending from being over loaded and a WDH will add weigh to the trailer axle, if you load your Rpod close to the limit a WDH can put you over. This is why I asked how it tows without one. I have towed trailers for over 40 years and have never needed one for a trailer under 4000 lbs.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2707 |
The only challenging thing about installing a WDH is that a couple of the torque values are ~~ 250 ft-lbs, and most people don't have a torque wrench that goes that high. It is not terribly difficult to MacGyver a workaround though.
richfsi ![]() Newbie ![]() Joined: 28 May 2020 Location: Madison, WI. Online Status: Offline Posts: 9 |
Thanks to all for the good education and great help!
Thanks for all the great help Fred.
Be well! Rich
Rich, yes, I did the installation on my e2. It comes with a step by step instruction book which can be downloaded from their web site too. It's mostly a matter bringing the trailer and TV back to level positions and torquing the bolts the proper values. Here is the Fastway manual site: https://www.fastwaytrailer.com/pdf/FW_Flash-E-Series-Instructions_DTBM521_PRINT.pdf
I have this hitch: https://www.etrailer.com/Weight-Distribution-Hitch/Fastway/FA94-00-0600.html??feed=npn&gclid=EAIaIQobChMIp6jym-fb6QIVUr7ACh3nsgMPEAYYBCABEgIUKfD_BwE Please feel to pm me and I'll send you my phone number if you want to talk about it on the phone.
I would recommend the Fastway E 2. It's the only one I've ever used, so I don't claim to be an expert. The E2 has never given me a problem, It's easy to put on/off, and i've made 90 degree turns backing in without removing it. As far as "do you need it" I would say this. If when you hitch up your pod / camper, and the back end of the tow vehicle moves down, you NEED Wdh. There is no doubt that as the back end goes down, the front end goes up. If anyone wants to argue that having your steering wheels making less contact with the road is a good thing, Please don't tow thru my state. Not to mention the added sway control. Sway can happen at any time, by a number of different conditions. Just because it towed great on tuesday, it might not be so good on friday. Just having one wheel catch a pothole could cause it to sway out of control.
Morning Fred, did you do the install on your e2? If so how difficult. Can you provide the model information please.
Thank you! Rich
One advantage to a WHD is that it transfers weight to the front wheels, thus giving better steering control and, in front wheel drive vehicles, better traction for the drive wheels. We got a Fastway e2 to use with our Pod and now use it with our new trailer. It makes the ride vastly more comfortable and gives us much better directional control, both for the trailer and the TV. The WHD function is especially useful when you start getting close to the CGVW limit, which you will be with the Highlander. It's a small investment compared to the safety and comfort you gain.
Though I can't speak to setting up other brands of WHD systems, setting up the e2 is super easy. It adds about a minute or two to the hitch/unhitch process. The slowest part is raising the trailer with the tongue jack to allow the bars to be put into proper position on the L brackets. It really doesn't affect your ability to back up, unless you are on a steep uneven surface and need to make a very sharp turn. In that case, it's easy to pop off the spring bars before backing into the parking space.
WDH's work by reducing the load on the tow vehicle hitch and redistributing some of it to the trailer axle and the front axle. If you don't have one the load on the TV front axle goes down when you hang the trailer on it. WDH's do not increase your TV max hitch weight though, unless the TV manufacturer states that, and Toyota doesn't. So its not technically a matter of "needing" a wdh, if you are exceeding your tow vehicle max hitch load you have to reduce it. Its a matter of how the rig rides and having better control by having more load on the TV front axle, which is where your steering and best brakes are. I tow my 179 with a Highlander. You will enjoy towing much more with a WDH, I wouldn't tow my trailer without one.
I have a Curt WDH with separate sway control. Some WDH's have integrated sway control. The benefit is less stuff to take on and off the rig when hitching and unhitching. Personally, I prefer the two functions separated so I can adjust how much resistance to sway I'm getting based on conditions. If roads are wet or curvy I reduce the sway control effort. You can't do that with the integrated ones. It's a personal preference. I highly suggest that you weigh your rig axle by axle at a public scale so you know what you have. If you load that 190 at all heavily you will be at or even over the hitch weight limit of your Highlander. I'm right there on mine. Load up the TV and trailer as you plan to camp, including water if you plan to boondock. You can get your trailer hitch weight by going through the scales twice, once with the rig and once with the TV by itself. The hitch weight is the difference between the total of the two TV axles with and without the trailer. Do not tension up the wdh when you take these weights and leave the wdh in the receiver when you weigh the TV.
Page <1234> |
