David and Danette
Topic: Axle Risers Posted: 16 Jan 2011 at 5:20am |
WDH weight distributing hitch David
2014 Ram 1500 Quad cab
tpierce220
Posted: 16 Jan 2011 at 10:06am |
WDH = Weight Distribution Hitch http://www.etrailer.com/faq-weightdistribution.aspx
this_is_nascar
Posted: 17 Jan 2011 at 8:27am |
Weight-Distribution-Hitch.
"Ray & Connie"
- 2017 R-Pod RP-180
this_is_nascar
Sorry, didn't see the other replies.
"Ray & Connie"
- 2017 R-Pod RP-180
Gerald
Posted: 17 Jan 2011 at 10:22am |
Lou,
My axle risers are being shipped out today. Brandie at Forest River was very helpful. The first time I emailed them I had a reply within two hours.
BTW our first camping trip for the May 24 weekend has been booked at Ferris Provincial Park. We booked the same site we had last year but this time with the axle risers I won't bottom out when backing in to the site.................
2010 R-Pod 177 / 2009 GMC Canyon 4X4
Gerald, Lydia and The Boys (2 Shelties)......Canuck Podders
rpodcamper.com
Posted: 17 Jan 2011 at 3:48pm |
You will find it tows so much nicer with them on. Lot less worry about bottoming out.
Posted: 17 Jan 2011 at 6:30pm |
I've had mine for months now, still sitting in the box! Hope to get to it when it warms up some.
Posted: 02 Apr 2011 at 10:58pm |
I finally got around to installing mine today, wasn't as hard as I expected. It was nice pulling into my driveway tonight and not scraping in the usual spots.
Gerald
Posted: 04 Apr 2011 at 11:43am |
I finally got around to installing mine today, wasn't as hard as I expected. It was nice pulling into my driveway tonight and not scraping in the usual spots. |
Hope to get mine installed in the next couple of weeks (If we don't get any more snow)
The instructions that came with the risers said to jack up the frame and place the axle stands under the frame. Is this what you did or did you jack up the axle till it was about 4 inches off the ground, place the stands under the frame and then lower the axle enought to install the risers? Also a good point about the brake wires.
Thanks
Posted: 04 Apr 2011 at 12:21pm |
We jacked up the frame just behind the axle, then put jack stands just behind the jack, on both sides. It was hooked up to my TV the whole time so it had support up front. In hindsight I should have put jack stands in front of the axle too, that's a lot of weight to suspend from hitch ball to rear jack stands.
