  New Posts New Posts RSS Feed: Stainless steel screwd
Topic ClosedStainless steel screwd
1liquid1 View Drop Down
Direct Link To This Post Topic: Stainless steel screwd
    Posted: 06 Apr 2020 at 12:34pm
I need to know what size stainless steel screws to use to replace my old screws.    And is there a u tube to show just where all the screws are?
Penny Greer
Buffalohunter View Drop Down
Direct Link To This Post Posted: 06 Apr 2020 at 2:30pm
A good hardware store would be a start
podwerkz View Drop Down
Direct Link To This Post Posted: 06 Apr 2020 at 4:26pm
It would be about as easy to look at the trailer to find all the screws as it would be to find and watch a youtube video about it, if one even existed.
And yeah, take a few samples to a good hardware store or big box home center...they will probably have what you need.
Jeepinator View Drop Down
Direct Link To This Post Posted: 09 Apr 2020 at 9:14am
You may need to be a member of the RPod Ownere group on Facebook to access this - https://www.facebook.com/groups/RPodOwners/permalink/10156315531555808/
It’s very detailed on replacing the screws
2018 Jeep Wrangler Willys
2017 179
Direct Link To This Post Posted: 09 Apr 2020 at 10:03am
Yup. Closed group. I can not in good conscience join FB.
Direct Link To This Post Posted: 09 Apr 2020 at 10:20am
+1 to Glue Guy.
tcj View Drop Down
Direct Link To This Post Posted: 09 Apr 2020 at 10:44am
Zukerberg will own your soul.
2018 R-pod 180 Hood River Edition
tcj View Drop Down
Direct Link To This Post Posted: 09 Apr 2020 at 10:46am
So is corrosion of screws in an Rpod a common issue?
Direct Link To This Post Posted: 09 Apr 2020 at 11:25am
+2 on the Slayer. Yup, that was Zuck’s nickname at his Hahvahd frat house.
Direct Link To This Post Posted: 09 Apr 2020 at 12:42pm
Rust is common to all screws made of steel when there is moisture available.  I have had 2 FR trailers and they don't seem to be out of the ordinary, insofar as rust is concerned.  If the screws are rusting where there should be no moisture, it's an early warning sign that water is getting into where it shouldn't.  Parts of the screws that are exposed to the outside will normally show some rust if not powder coated or painted.  If the shafts of the screws are rusting, you may want to try to figure out where the moisture is getting in and fix it.  If it's coming in through the screw hole, then take the screw out, coat the threads with marine sealant caulk, and replace them.  If it's coming in through some other source, then you'll need to track it down.
