  New Posts New Posts RSS Feed: condensation
Topic Closedcondensation
Direct Link To This Post Topic: condensation
    Posted: 08 Oct 2010 at 9:29pm
Very similar to what pup owners use - radiant barrier in the windows between the tenting and screen.  Sometimes the bubble wrap variety, sometimes the flat type.  Very helpful keeping the heat out or in depending on the season.
TIDALWAVE View Drop Down
Direct Link To This Post Posted: 08 Oct 2010 at 8:24am
I had condensation on windows on both my RV and my Pod during cool nights.  I found a really good insulation product at Home Depot.  It is a roll of aluminized mylar bubble material (similar to the bubble material used in packing).  It is slightly stiff when unrolled.  I carefully cut the material to the same dimensions as the interior window framing.  I can simply unroll the cut sheet and pop it into the window frame.  Because of its mirror coating, the bubble material acts as an opaque night shade and because of the air containing bubbles, it is a very good insulator.
I have also used it during the summer, when it was very hot and sunny out.  I would install the
shade on the sunny side of the Pod...it made a lot of difference in keeping the sun from overheating the interior (the Pod curtains really only give privacy not insulation).
TIDALWAVE
Direct Link To This Post Posted: 05 Oct 2010 at 12:48pm
This A/C that I'm considering putting in has a "dry mode" (dehumidifier).  Although it can't do heat and dehumidify at the same time so that won't help much in the fall/spring.
this_is_nascar View Drop Down
Direct Link To This Post Posted: 05 Oct 2010 at 9:24am
Go to Lowes, Home Depot, Wal-Mart or the like and look for a product called Damp Rid.  I have the disposable bucket-type as opposed to the hanging one or the refillable ones.  This product is the bomb and works like you wouldn't believe.  I keep my rig so cold in the summer, I'd constantly get severe condensation.  This Damp Rid took care of all of that.
"Ray & Connie"
- 2017 R-Pod RP-180
Kickstart View Drop Down
Direct Link To This Post Posted: 05 Oct 2010 at 2:04am
Hey, Brin, that's a great idea! With all the rigs we've had we never even considered a dehumidifier. I'm gonna give that some serious thought, as we do quite a bit of winter camping.
Direct Link To This Post Posted: 04 Oct 2010 at 8:20pm
kickstart, yes, the 'pod is very well insulated.  If I remember right it has 2" in all the walls (vs. 1" for most trailers), and several inches in the floor.
Brin View Drop Down
Direct Link To This Post Posted: 04 Oct 2010 at 8:16pm
We bought a really small dehumidfier that we run at night ( as long as we have shore power).  It seemed to help with the condensation as the bed was getting very wet at the back window in our 175.
Terri and Craig and Panzer
2009 - 175 RPod
2000 Ford F250 XLT Extended Cab Diesel
Direct Link To This Post Posted: 04 Oct 2010 at 7:24pm
We minimize the condensation in our 175 by cracking one of the windows at the head or foot of the bed, opening the roof vent, and running our space heater either on fan or heat depending on how cool we expect the night to get. You can do well by running the bathroom fan instead of the the space heater, but the bathroom fan is a little louder and I don't want to run it continually, as it would be more trouble and expensive to replace.
Over the years, we've had 5 trailers, 2 camper vans, and 3 pick up campers. The RPod has shown the least condensation of any of our rigs. The RPods must be pretty well insulated, as the only other trailer we've had with minimal condensation trouble was an Artic Fox with a winter package, and it was REALLY insulated. Running the gas furnace has always seemed to increase our condensation problems in any of our camping rigs.
Direct Link To This Post Posted: 03 Oct 2010 at 10:10pm
I do what Outbound does, and also have a problem with condensation on the rear window.  I just found an idea yesterday which I may try.  Get the 1" blue/pink foam from the Big Orange Store (I already have a sheet hanging around), and cut that to size.  Acts as a great blackout blind, and hopefully keeps the water vapor away from the cold window surface.  I wonder though if it would do better on the outside of the window to instead keep the windows warmer.
Outbound View Drop Down
Direct Link To This Post Posted: 03 Oct 2010 at 7:00pm
On our 171, I usually leave the vent hood open an inch or two and crack open both the front windows to help keep condensation down.  Cool, moist air behind the curtain over the rear window usually causes a great deal of condensation too, so the curtain is left open when possible.
On really cold days (just above freezing), I've also found condensation on the walls below the top of the mattress.  I haven't done anything about it yet, but some reflectix may be in order.
