Page <1234> |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6428 |
![]() Posted: 27 Jan 2019 at 8:30am |
Right now the 6" mattress is not working out very well as it is not expanding beyond 4". I already contacted Zinus' customer service. I will give it a couple of more days per the agent. If it still does not expand, I will contact Amazon to replace it. I may go for a refund and change brands, which would be too bad as my 10" Zinus is quite comfortable and is shortly going to be moved into our house for use there with a foam block to fill the space to make it a full queen length. The issue may be that the mattress was manufactured in September 2018 and I ordered and received it in January 2019. The box states to unpack within 72 hours of receipt. That does not account for the four months of shipping and storage from when it was manufactured. The top memory foam portions seem to have expanded, but the base layer is the one that is still not expanded. I'll let you know more in a couple of days. I really like the lighter weight and flexibility of the 6" mattress. An 8" mattress would be over 10 lbs heavier and stiffer. It would be a good choice as it still would be more flexible and lighter than the 10" mattress.
Wepod ![]() Groupie ![]() Joined: 07 Feb 2017 Online Status: Offline Posts: 82 |
Thanks all for the replies. We used a memory foam topper on top of the old mattress but unfortunately the OEM mattress foam still broke down. We are using our pod about 10-12 weeks a year right now so that could be why the OEM mattress is going flat.
I was looking at the 8" zinus as a replacement for us as I don't go under the mattress but once a year to winterize. I am also planning on installing a access door from the outside and rerouting the plumbing valves near the pump so they can be reached to make winterizing easier. Stephen I look forward to hearing about the 6" mattress as that may be a good option for us to |
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2709 |
Us too. We have always used relatively "firm" mattresses, and when we tent camp, plush to us is a thermarest, which is only 1" thick. The 6" mattress in the R-pod has seemed luxurious to us.
We did have an old 2" thick semi-firm chunk of foam that was left over from the larger chunk that we used as a mattress in the back of the pickup that we put under the R-pod mattress. That is what does it for now. The original mattress has seemed to compress since we've gotten it, so I can foresee a time in the future when it will have to be replaced.
Kup-Pod ![]() Senior Member ![]() ![]() Joined: 08 Jun 2017 Location: Guelph, Ontario Online Status: Offline Posts: 153 |
So we might be classified with the "odd ball" category and also still have our RPod mattress. We put a dense foam topper on it and also bought a mattress plush quilted cover to enclose the mattress and topper as one unit. That seemed to do the trick for us.
Keep in mind, we are all different shapes and sizes with different definitions of comfort, so what works for one may not work for another! :-) |
2017 RP-178
2021 F150 5.0l "Lead me on a level path" |
Motor7 ![]() Senior Member ![]() Joined: 09 Jan 2019 Location: E. TN Online Status: Offline Posts: 196 |
We just ordered a folding 6" fullsized queen for the 176T from Amazon for $215:
https://www.amazon.com/gp/product/B00W67PH2Q/ref=ppx_yo_dt_b_asin_title_o01__o00_s00?ie=UTF8&psc=1 Since the bed is North/South and hangs over the dinette we didn't need a short Queen....being 6'4 and the wife 5'11 a full length will be glorious.
2016 R-Pod 176T
crankster78 ![]() Senior Member ![]() Joined: 08 May 2018 Location: Minn Online Status: Offline Posts: 163 |
Greetings: I travel by myself and purchased a inner spring twin. It's much easier to change the bedding and I installed a shelf behind it. I have a stereo system on the shelf and storage underneath. It works great for me. Crankster78 R-179
Crankster 78 R-179 2015
Happy Tripping ![]() Senior Member ![]() ![]() Joined: 27 May 2014 Online Status: Offline Posts: 473 |
We are odd ball members if that bizarre group that actually don't mind the standard r-pod mattress. That being said, ours is getting old and needs to be replaced.
Has anyone tried the apparently new 'mattress topper' as an alternative to getting a whole new mattress?? https://www.zinus.com/collections/mattresses/mattress-type_memory-foam |
The six inch mattress arrived today and is expanding now. It will take a while before it is fully expanded and I can give an objective evaluation. I can provide some first impressions though. First off, it is amazing what a difference that 28.1 lbs of weight makes. The 6" mattress is something Ican move easily. I expect it will still be easy once it is fully expanded. Second is the thickness. I will need to wait to after it is fully expanded, but partially expanded, it is easy for me to fold enough to get to access things underneath. As for comfort, I can't report on that until we have a chance to test it. One good thing about geting it now is that the odor of the new foam has time to dissipate before we need to use it. Lying down on it while partially expanded just does not work for providing an evaluation. I think it will be a bit more firm than the 10" model. My wife had mentioned the 10" model which we purchased in 2016 seems to have developed impressions where we lie. While Ido not find this to be a problem (I had not really noticed it), she does not care for that part. Now to figure out what to do with a 10" mattress that is in too good a shape to throw away and for which we have no good storage option.
We did the same in our 2011.. except we didn't last a "few nights".. we lasted one night in the driveway. ![]() |
I've said this before, but it's worth repeating. We use a 4" piece of seat cushion foam that's real firm. My wife made a couple of covers for it. It's light, very comfortable [this foam comes in various densities to meet your hard/soft mattress preferences], and easy to move. Being relatively light, it's easy to get at the space below the bed where we have a lot of stuff stored. Cost: just a tad over $100 including the cloth to make the covers.
Page <1234> |
