  New Posts New Posts RSS Feed: Generators
Topic ClosedGenerators
Butterfly_Lee View Drop Down
Direct Link To This Post Topic: Generators
    Posted: 14 Sep 2010 at 1:56pm
Originally posted by Runebane
Thanks all for the feedback, and Outbound thanks for reminding me to check about the load... the 62db was for no load and econo mode on.
Looks like it's back to searching for a good deal.  Maybe I should check out Craig's list for a used Honda 2k ;)
That's How I got mine, even if I have to get another or the campion model I'm still ahead a little.\
LeeClap
Still a work in progress, lots of pictures.
http://podterfly.blogspot.com/
Runebane View Drop Down
Direct Link To This Post Posted: 14 Sep 2010 at 8:37am
RP-177
cane2 View Drop Down
Direct Link To This Post Posted: 14 Sep 2010 at 7:42am
Hi Lee and Myra miss you guys. I have been hiding out here most of the time. As you know we sold our place in weslaco but planning on coming down in the first part of Nov as i do not want to have to winterize the pod. I think the doctors will let me out of town as i am still a survivor as of now.
My air is a Dometic Duro-Therm model 579 which is a 11,000 btu unit with heat strip, It draws 8 amps for compressor when running i do not know what it uses for start up. Run your fan on high and like you did no eco on it should run the air.
We are going to take the pod up to Lake Superior next week, Duluth, as the leaves are starting to change, will need heat at nite up there on lake. Hope to see more pods on the way. Keep the storms out of there.
Direct Link To This Post Posted: 14 Sep 2010 at 7:28am
This post needs to be deleted but cannot edit.
Direct Link To This Post Posted: 14 Sep 2010 at 12:10am
My Podterfly is in storage (about 200miles away), but when I go the Round Up next month I'm going to make sure I have the manuals for the a/c and the generator, plus fresh spark plug and gas.   Hopefully we (me and other podders) can find a little time to run both through a couple of trials.  It's hard for me to be on the inside and see/hear what the generator is doing on the outside.  Already have a copy of the usage amps from another post, to make sure everything gets turned off.
To answer your question yes eco was off,  when i could get the a/c to kick in I just ran a couple of fans and put it back on eco (by the way it ran for over 6 hours without a problem).
LeeClap
Direct Link To This Post Posted: 13 Sep 2010 at 10:12pm
Have you tried with eco mode off?
Direct Link To This Post Posted: 12 Sep 2010 at 9:31pm
HI cane haven't seen you on in a while.  Hope both of you are doing well.  Are you guys coming back down to Texas for the winter?
I have a 11,000BTU a/c and haven't been able to run the A/c and I have a 2000ihonda does that make a difference.  I goes into overload and turns off when I turn the A/c on.  Is there soemthing special I should be doing?
LeeClap
Direct Link To This Post Posted: 12 Sep 2010 at 5:07pm
I have a Honda 2000 and it runs my air or heater, BUT i did not get a 13,500 BTU air I had the dealer install a 11,000 btu air with heat strip it draws 8 amps for the compressor. The air is Dometic Duo therm 11,000 Btu. Just make sure you run the fan on high speed then the compressor will not shut down the generator. The 11,000 is plenty big for the pod i wish i could have found a 7,000 at the time i would have put that in instead.
Outbound View Drop Down
Direct Link To This Post Posted: 12 Sep 2010 at 12:33pm
62 db is bordering on unacceptable and your neighbours will certainly be very aware that you're running a generator.  At 15', that would sound like putting your ear next to a washing machine.
Is that 62 db at the rated load (I'm guessing 1600 watts for a generator denoted a '2000', but I could be wrong), or at idle?  I've also seen some generators spec'd at 25% of rated load.  If thats at idle, the noise will ramp-up quite quickly (70 db and above) to a very unacceptable level.
You might be interested in reading a recent off-topic post about generators that was buried in another thread: http://rpod-owners.com/forum_posts.asp?TID=1309&PID=11794&title=measured-wattage-of-pod-appliances#11794
Direct Link To This Post Posted: 12 Sep 2010 at 10:54am
I've been looking into getting a small generator that will run the AC for when we're not at a camp with electrical hookups.   I'm wondering if anyone has used the Honeywell 2000i generator (or the Honeywell 2000... from what I can tell the only difference is the "i" is their CARB compliant one for Californians)?
2100 watt surge, 62db at 7 meters (15'), and best part they have it at Costco, so I can take it back if it doesn't work out for us.   But, again, just curious if anyone has used or is currently using one of these.
Thanks,
Runebane
The i stands for Inverter Generators provide cleaner energy to power sensitive electronic (laptops etc).  When I was looking someone purchased a honeywell and didn't like it(that was only one post).  Unfortunately I don't think it was handle the load on the A/C.
I have a 2000ihonda and can run the fan but not the a/c compressor (so far I want to try different combinations of turning off switches but haven't had the opportunity).  Right now I'm not in a situation that I will need to run the A/C off the generator, but when I start traveling more I'll probably buy a second generator and run them together.
So right from the get go you might consider buying two (cheaper then one HONDA), it's my understanding that they need to be the same type/company to run together.
My two cents
LeeClap
