  New Posts New Posts RSS Feed: Bearings and Wheel Problem-Twice
Topic ClosedBearings and Wheel Problem-Twice
CAhikers2x2 View Drop Down
Direct Link To This Post Topic: Bearings and Wheel Problem-Twice
    Posted: 20 Nov 2018 at 9:34pm
Thank you for sharing. This sounds like we have some similar symptoms. The brakes wanting to stop quickly and the wheels not vertical to the ground...is this called camber? On trailers like our pods, are the wheels supposed to be at a vertical camber?
We do have the west coast Hood River Edition with the beefy tires so tire wear is something I would not notice.
Somewhere I recall the Hood River Edition having a "dropped axle". Is this so and is this common with other trailers?
Many thanks, this sounds so similar.
Joanne
Roger & Joanne
1 Camper Dog "Scout"
2015 RP 177
2016 Nissan Frontier
2001 Coleman Westlake
Direct Link To This Post Posted: 20 Nov 2018 at 10:19pm
I'm, not sure what you mean about a "dropped axle." It could be the angle of the arm to which the spindle is attached. On mine, it is angled a little upward. It was set to a downward angle starting in 2017 (I think). Mine has riser blocks but the ones with the re-clocked axle did not come with riser blocks although they can be added for even more height.  I can't find any thing about a "dropped axle" when I am searching.
Direct Link To This Post Posted: 21 Nov 2018 at 1:23am
Thanks Stephen for helping me understand more of the mechanics of our Pod. I will check these links and pursue where I picked up "dropped axle". I could be using the wrong terminology for exactly what you are telling me. Our Pod does seem to sit high off the ground. But it came standard that way because of the large tires. Everything was stock, from my understanding when we purchased it new.
I have been overwhelmed with everyone's great interest.
Thanks again, Joanne
Roger & Joanne
2015 RP 177
Direct Link To This Post Posted: 21 Nov 2018 at 7:23am
We are both looking for answers on this issue. When I hear from the dealer's service department, I will let you know.
Woodmiester View Drop Down
Direct Link To This Post Posted: 21 Nov 2018 at 8:18am
All of these issues were experienced by me on the bent axle issue.  A very easy diagnosis.  Merely stretch a string from one end of the axle to the other.  The string should sit flat on the axle from end to end.  It if does not, you have a problem.
Swampfox
Direct Link To This Post Posted: 21 Nov 2018 at 2:56pm
Thanks. That is a simple way to check. When we get it back (probably before we leave the service department) I will ask if they checked for a bent axle (they are supposed to). If not, then I will have some string with me to do so.
Direct Link To This Post Posted: 21 Nov 2018 at 9:18pm
I look forward to hear from you about what your RV techs find.
Thank you.
Axle was mentioned by our RV tech when the tow truck dropped it off about 100 miles from home.
Joanne
Roger & Joanne
2015 RP 177
seafans View Drop Down
Direct Link To This Post Posted: 28 Nov 2018 at 6:55pm
CAhikers2x2 View Drop Down,
have you checked the total axle weight of the trailer?  Next time you are out run the trailer through a weight station that is closed so they don't git upset.  Go very slowly over the scale.  The axle weight should not be over about 3800-3900 to be safe.  Depending on the empty weight. They only have about 800lbs. useful load.
Direct Link To This Post Posted: 29 Nov 2018 at 9:20am
That would be overweight for a 177. Full up weight on a 177 should be around 3750 lbs with maybe around 400-450 on the tongue. So without a WDH, the axle weight I would expect to be in the neighborhood of 3300 lbs.
As usual, YMMV.
Direct Link To This Post Posted: 05 Dec 2018 at 11:23am
The dealer said measurements were sent to LCI. I have not yet heard the results. I suspect a new axle may be in our 'Pod's future.
