Page <123> |
![]() Posted: 01 Nov 2018 at 10:46am |
Found it: http://www.rpod-owners.com/forum_posts.asp?TID=10996&KW=spoiler+video&PID=103301&title=towing-mpg#103301
Check out the link in the text that'll take you to several video simulations. It says "on that channel" in blue.
Kewl lostagain,
If the airstream is going to become unstuck from the camper, which it inevitably will with the steep backs of our trailers, then the value of a spoiler is to try to get that airflow away from the trailer as much as possible as soon as possible. Hence the term 'spoiler". The video simulations seem to show that a spoiler won't do much to move the needle, the negative pressure gradient behind the trailer is just too big to overcome. That was what I suspected when I said I thought the FR spoiler was stuck on there more for looks than functionality. One thing that might help is something like these vortex generators which go aft on the sides of RV's, but boy are they ugly. http://www.airtab.com/application-rv.htm I can also see why you might get a little improvement with a spoiler placed aft on the wo vehicle to try to keep the airstream out of the space between the TV and the trailer. Like this: http://www.purplelineusa.com/products-aeroplus.php
The second one looks a little like the wedge shaped roof of my camper shell [topper to those in the east].
My solution is just to <60 and not worry about it. So does the wind suck or push a sailboat sailing on any point of sail other than dead down wind?
Everyone has different priorities. If FR did everything people here said they should the Pod would cost more than an Airstream, weigh as much as a semi truck, and each trailer would have things added that would produce a many complaints as the current models do. They are what they are.
+1 to Keith. There is a reason is it affordable and thus so popular. Some of the newer models have many of the mods some of us have applied. It's never going to be a 30K trailer for 18K, hopefully.
+1 to Kieth & Da. And hopefully it's never going to be a $18K trailer for $30K.
Lostagain, the way you phrased your question and knowing you're an experienced sailor I think you already know the answer. A sail is an airfoil unless going downwind. A vertical airplane wing with pressure differential between the fore and aft surfaces driving the boat. So, yep, it sucks.
Keith-N-Dar I agree that the rPod can't have all kinds of things added to it without costing too much. I'm not suggesting adding anything, quite the opposite. The difference here is that the spoiler costs FR money and doesn't appear to add any useful benefit, in fact it increases the risk of leaks. It appears to be purely someone's idea of what's aesthetically pleasing. It would be a win win to just leave it off.
it could be worse though ![]() ![]() |
When I had the spoiler added it was for a recall about clearance lights. In retrospect, especially since the dealer didn't do such a hot job wiring the fender lights, I would have preferred to mount a small bar across the back to hold the 3 lights with no roof penetrations, instead being mounted by vertical supports on the wall where there are frame members available to screw into. But, now that I have the spoiler, I have to live with it and have it well sealed for probably as long as I own the trailer. I posted fotos a long time ago.
I'll be living with it too I guess even though I'd really like it off of there because its going to interfere with my solar installation.
Actually in thinking about it more, it would probably be easier to manage potential leaks if it was removed because then I could directly see and seal the penetrations themselves. To deal with the lights I could just get a DOT approved trailer id light bar from Amazon for 10-15$ and attach it to the back frame of the rear solar module. Does anyone know what adhesive/sealant FR uses to attach the spoiler and if there is a way to remove it cleanly from the fiberglass? Mine is a 2015.
Just use mineral spirits. They won't damage the fiberglass and will remove the Dicor sealant. You could finish with some denatured alcohol to make sure the surface is thoroughly clean.
Page <123> |
