  New Posts New Posts RSS Feed: water heater
Topic Closedwater heater
TheBum View Drop Down
Direct Link To This Post Topic: water heater
    Posted: 26 Sep 2018 at 11:01am
I use the same Harbor Freight torque wrench I used to set up my WDH. I don't have an extension, so I use a reducer and an expander hooked together to get the spacing I need between the 1-1/16" socket and the torque wrench. I have to be careful not to over-torque the rod.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
grizwalsh View Drop Down
Direct Link To This Post Posted: 26 Sep 2018 at 7:59am
Had to buy a $14 socket but I could only get one in 3/4 inch drive--don't have that so I almost bought a $30 ratchet till I found out you can get an adaptor for 1/2 inch--the struggle continues
grizwalsh
podrunner View Drop Down
Direct Link To This Post Posted: 25 Sep 2018 at 7:27pm
I have gotten by with an adjustable wrench and a pair of vice grips.  Works for me...
2010 R Pod 151
2017 4runner
2006 Honda Metropolitan
Direct Link To This Post Posted: 24 Sep 2018 at 7:23pm
A 27mm metric should work pretty well too.
Mirado View Drop Down
Direct Link To This Post Posted: 24 Sep 2018 at 4:30pm
Originally posted by Ben Herman
Someone I know very well had this happen to him also. Doubt it'll happen to me twice!
Ditto on that....I won't mention his name so as not to embarass him....
Miriam and Doug
2015 Rpod 181G
Silverado 1500
riotkayak284 View Drop Down
Direct Link To This Post Posted: 24 Sep 2018 at 2:38pm
I always remove the low point drain plug before too....
Ben Herman View Drop Down
Direct Link To This Post Posted: 24 Sep 2018 at 1:30pm
Originally posted by john in idaho
Just don't forget to depressurize the water tank - turn on a faucet with the pump off until it quits dripping.  I forgot once and it blew the anode rod and the socket wrench about 15 feet.  Rather impressive.   And then I needed to go get some dry clothing.
Direct Link To This Post Posted: 24 Sep 2018 at 1:13pm
Depressurization is a little faster if you slowly open the pressure relief valve on the water heater. I've also found this to be a good thing to do when filling the hot water tank.
Alan
Three cats
Direct Link To This Post Posted: 24 Sep 2018 at 12:38pm
And once again the Rpod forum comes through--thanks everyone!
grizwalsh
john in idaho View Drop Down
Direct Link To This Post Posted: 24 Sep 2018 at 12:19pm
