Page <1234> |
cgarb ![]() Groupie ![]() ![]() Joined: 27 Mar 2011 Location: California Online Status: Offline Posts: 95 |
![]() Posted: 15 Jul 2018 at 12:36pm |
We had that problem and it turned out the refrig had just up and died. We had to have it replaced. Our repair person said that it is a common problem with the older model (ours is 2011) Dometic refrigs. The new one he put in works better - cools faster and no problems with it.
Carol
177 HRE rpod 2014 Honda Pilot |
What brand and model was installed?
I don't know the model number. The manual has several model numbers on it. Not sure which is/was ours. I just know that both were/are Dometic. There isn't anything on the refrig itself either, much to my surprise. The newer one is an improvement on the old one, according to our service guy. I think it is the only brand that would fit in the space in the pod. Sorry I don't have anything more specific for you.
Carol
If it is Dometic, look inside where the crisper drawer is located (you may need to remove it). There should be a label there.
Ben Herman ![]() Senior Member ![]() Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 356 |
Stephenh - I'll look up the model info on mine tomorrow (have guests coming in a few minutes). Its a year old, works beautifully. No trouble getting very cold fridge temps w/propane even on #4 setting.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2702 |
I thought they surely must have a sticker or something "somewhere"... However, I looked all around the front outside, inside, in the freezer compartment, under the freezer compartment, in the crisper. Nothing nada. Then I popped off both of the vents on back, and checked all around in there too. Nothing. There is a little label near the bottom with some safety information, but no model numbers. Then I thought, how many 3.7 cu-ft 3-way refrigerators can they make? I found one. Here it is:
Hm. My post didn't seem to go through. I did find the info behind the crisper drawer. It was too hard for me to read so I took a picture of it. It is a Dometic, Type C40/110, Model number: RM 8551. Hope that helps. Good luck!
Carol
I wonder what the difference is between the 8501 which is the model in mine and the 8551.
I wonder if it is the earlier model like we had to replace. The front of the owners manual lists the models it covers in 3 groups: RM 8501 - RM 8505, RM 8551-RM 8555 and RML 8551-RML 8555.
Maybe if you went to the Dometic site if you could compare them.
Carol
The 8501 and 8505 are 22.36 inches deep The 8551 and 8555 are 24.52 inches deep I misspoke earlier. All four models are 32 inches tall. The differences are in the depth. I'm now thinking the lack of indicia is intentional. This allows them to switch around the different refrigerators with little or no consequence. How would we measure the depth without removing the fridge?
Page <1234> |
