  New Posts New Posts RSS Feed: Generator
Topic ClosedGenerator
 Post Reply Post Reply Page  <12345 7>
Direct Link To This Post Topic: Generator
    Posted: 16 Jun 2018 at 3:20pm
I run my AC on a Generac IX 2000 just fine, no mods, if there is an issue I turn off the converter CB which disables the charging circuit.
FrayAdjacent View Drop Down
Direct Link To This Post Posted: 17 Jun 2018 at 11:06pm
When I'm camping, I'll usually set up my 100W solar panel connected (via a charge controller) to the battery. Turning off the converter does alleviate load on the generator. Not a bad idea to do so unless you want the generator to charge your battery or provide all the 12V power needed.
Direct Link To This Post Posted: 18 Jun 2018 at 11:04am
Originally posted by FrayAdjacent
Posted as a separate post:
I brought my 176 home from the dealer yesterday. Didn't own it for 6 hours before I began modding! I installed a MicroAir Easy Start and went through the start cycles on AC power from the house. I then tried my 2200W Westinghouse generator. It started the AC just fine. I then shut the AC off and switched the generator to Eco mode, and the AC started just fine!
SO... I'll always recommend for small campers like ours, a 2000W generator, with the MicroAir Easy Start installed will be perfect for running the AC on generator.
I took a quick look at the MicroAir Easy Start and it looks quite different than the hard-start capacitor I tried and removed because it made the AC harder and not easier to start. I'll have to see what is required for our AC unit.
How hard was it to install?
voy108 View Drop Down
Direct Link To This Post Posted: 18 Jun 2018 at 12:46pm
Hey Folks, any precautions to take when switching off the Converter CB? I'm going to give my smaller gen another try. Looking at my CB panel, Main 30amp, a/c is a 20amp. i agree, the smaller Predator should work except it has a note on the 120v plug...do not exceed 18 amps. That may be why it overloaded.Think???
Thanks
Doug
2017 R-Pod 171-green
2004 Ford Explorer
Lucy, my Terrier Rescue
Direct Link To This Post Posted: 18 Jun 2018 at 1:53pm
That is because starting surge on the AC is much higher than the running watts. I was on the MicroAir site looking at the Easy Start. I think if you were to install one of those, your smaller Predator should then work.
Direct Link To This Post Posted: 18 Jun 2018 at 3:53pm
Thanks Stephen: Since I have both predators I think I will forgo the Easy Start and sell the little guy and go with the 3500. Thanks again for your input. I can see further running of the 2200 will not produce a different result unless I have the ES installed. Weight will be a concern so will need to do some appropriate balancing of my travel items since I hope to be on the road for 4-6 months. This summer will be a real learning experience. Smile
Doug
2004 Ford Explorer
Direct Link To This Post Posted: 18 Jun 2018 at 4:07pm
The AC doesn't exceed 20A. At that point the CB kicks. It is actually lower than that at both start up and run.
rawest50 View Drop Down
Direct Link To This Post Posted: 18 Jun 2018 at 4:22pm
There is s lot of great info being posted. The reason I started the post we went camping in East Tennessee and out camp site has water and electric. We drove over to the Smokie Mountain National Park and looked at a RV campsite at Cades Cove. There was no electrical or water. Just trying to prepare for a camping event without electricity. Water I can handle. Just getting feed back. Thanks.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Direct Link To This Post Posted: 18 Jun 2018 at 4:25pm
So Rawest50, what generator do you have, if you have one and maybe some folks could give you tips on using it, we could cut to the chase.
Direct Link To This Post Posted: 18 Jun 2018 at 4:39pm
I have 2 for my house but. 1 big that would power everything on the RV but loud. I have a 2200 watt but it only has the 20 amp plug. Operates at 59 dB which should be okay noise wise in a National Park according to a previous post. With 20 amp service what can I operate on the RV at the same time? AC, refrig, TV, lights? Here at the house the trailer is on a 15 amp circuit. I can operate things but have to watch what I have on.
2017.5 RPod 179
2 Weiner dogs
