  New Posts New Posts RSS Feed: Replacing interior lights with LED's
Topic ClosedReplacing interior lights with LED's
pod-head View Drop Down
Direct Link To This Post Topic: Replacing interior lights with LED's
    Posted: 18 Jul 2010 at 7:45pm
In an effort to maximize the battery life for our annual week-long boon docking trip,  I recently ordered some LED's to replace the interior lights. We finally had a weekend to go camping, so this project was at the top of the list. Since I already had the multimeter out, I decided the check the current draw of the regular bulbs vs. the LED replacements. Wow-- what I found was really surprising.
***The fine print: These LED replacements are about 1/2 as bright the standard bulbs. They are adequate for eating or playing a game, but it might be difficult to read something with, uh, fine print. I just went back to the website (superbrightleds.com) and ordered some larger LED arrays that will generate more light. I'll report back when I have a chance to test these.
I turned on one of the double overhead lights (RP177) and found it used 2.460A. I replaced the bulbs with the LED's and remeasured the current at 0.040A. Thats less than 2% of what the std bulb used. Thats huge!
So let me put this into a battery life perspective. If you have a 75Ah (Amp*hour) RV battery, you could estimate that it would sustain a load of 1 Amp for 75 hours (under ideal conditions, battery capacity is effected by load, other factors effect capacity, your mileage may vary, blah, blah, legalese). Using the numbers from above:
std bulb:      75A*h/2.460A => 30.5 hours of use
LED array:    75A*h/0.040A => 1875 hours of use
Thats a BIG difference.
'10 RP177 towed with '10 Tundra
D and T, and sometimes Nala the cat
Direct Link To This Post Posted: 18 Jul 2010 at 7:49pm
Part II (Continuation from the post above)
So, since the multimeter was already connected to the battery, I decided to measure the other possible 12V loads in the pod:
Load Current (A)
baseline (see footnote 1)
0.140
outside light 1.590
bathroom light 1.420
sink light 2.460
single overhead bunk LED 0.020
both overhead bunk LED's 0.040
double overhead LED 0.040
bath fan speed 1 1.270
bath fan speed 2 1.950
bath fan speed 3 2.960
tv booster 0.060
water pump 4.0-7.0A
(1) The baseline load is the fridge running on propane,with CO2 and propane detectors on; no lights or other appliances running.
Direct Link To This Post Posted: 18 Jul 2010 at 9:27pm
A great way to shed some load, thanks for the info.
TerryM View Drop Down
Direct Link To This Post Posted: 19 Jul 2010 at 7:01am
Happy to see your results.  I am planning on replacing my lights with LED's also.  From the same place even!  In the motorhome I had I replaced the lights with florescent lights and that made a big difference also.  But LED's are much better at saving juice.
Terry
popgoesweasel View Drop Down
Direct Link To This Post Posted: 19 Jul 2010 at 11:50am
how about some links to the bulbs that you have as replacements or the LED arrays that will generate enough light for reading.
I went to the web site but our pod is not where we live, I cannot figure out when are the correct replacement bulbs.
R171 2010
Frontier 2009
Site 40 Eastern Rally 2010
Direct Link To This Post Posted: 20 Jul 2010 at 3:54am
I'll check out mine today and post what type of bulb it has.  Single or double contacts.  It seems they would be single.
Terry
GrandPod View Drop Down
Direct Link To This Post Posted: 20 Jul 2010 at 6:42am
 The bulbs that come with the R-Pod are a 921 type. I replaced mine with Leds from Superbrightleds.com used the WLED-WHP10-D. Where there 2 921 type bulbs; I used 1 Wled-whp10-D Led. I tried the 6 led one but was not bright enough.
 The bulb for the outside light is a type 1141.
 I tried several different leds from sellers on Ebay but none of the ones I tried were bright enough; so I went with the superbrightleds.com one.
 Tom
Tom and Linda
R-Pod 177
Southwest Florida
Direct Link To This Post Posted: 20 Jul 2010 at 11:22am
Tom,
Thanks for tip on using a brighter bulb with more LED's.
URL for WLED-WHP10-D
Tiny URL for above
http://tinyurl.com/y9vlems
Ed
R171 2010
Frontier 2009
Direct Link To This Post Posted: 20 Jul 2010 at 10:16pm
Correct, the interior lights are 921. These are also called miniature wedge base bulbs:
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fmini-wedge.html
One of the claims on the above page is:
"The following 194/168 type bulbs will replace any miniature wedge base bulb with a 3 digit part number."
This, to me, means that 921's can be replaced by 194 & 168. We'll find out, since I just ordered some WLED-xHP10-DAC to go over the kitchen sink.
this_is_nascar View Drop Down
Direct Link To This Post Posted: 22 Oct 2010 at 2:53pm
I'm looking to replace my bulbs too.  What was the final outcome of this?
"Ray & Connie"
- 2017 R-Pod RP-180
