  New Posts New Posts RSS Feed: cord ring
Topic Closedcord ring
hogone View Drop Down
Direct Link To This Post Topic: cord ring
    Posted: 24 May 2018 at 5:34am
super glue was the trick!!!!!!    hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Direct Link To This Post Posted: 23 May 2018 at 1:39am
I accidentally ran over mine and broke it. I purchased a new ring and used hot water to soften the plastic flange so that I could work the ring over it. Then I fastened the plug to the coupler ring that came with the new ring (cheaper to purchase the set than to purchase just the ring) to flatten out the flange so that it would be in the proper shape as it cooled. I'm taking extra care not to run over it again.
Direct Link To This Post Posted: 22 May 2018 at 3:33pm
And to make sure it is fully inserted before tightening. Just like any coupler.
TheBum View Drop Down
Direct Link To This Post Posted: 22 May 2018 at 10:47am
It probably broke from being cross-threaded, which is easy to do. The trick I've discovered is to start by screwing it counterclockwise until the thread seats and then screw it clockwise to secure it.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Pod People View Drop Down
Direct Link To This Post Posted: 22 May 2018 at 8:31am
ours cracked  and I repaired it with super glue. still holding ok.  I think it cracked from either twisting it too tight on the pod or dropping the cord on the ground.  I try not to do either of these any more.
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 22 May 2018 at 7:52am
Threaded locking ring on female end of power cable? I never had one break. I also found new ones to purchase but no install info.
Direct Link To This Post Posted: 22 May 2018 at 5:45am
anybody have there electric cord nut(ring) that screws on the camper electric input crack/break?  i see you can purchase a new one but it sounds there hard to get on.  I'm not sure that made sense!!  hopefully so though.  hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
