east vs west (standard vs hood river) 172 |
Post Reply | Page <12345 6> |
corpod172
Newbie Joined: 17 Apr 2018 Online Status: Offline Posts: 22 |
Topic: east vs west (standard vs hood river) 172 Posted: 21 Apr 2018 at 11:53am |
yes, the dealer in Missouri sent me a pic, and I took pics of a local HRE... both welded.
corpod172
Posted: 21 Apr 2018 at 11:58am |
Wood River Pod
Senior Member Joined: 30 Sep 2016 Location: Wood River, ID Online Status: Offline Posts: 153 |
Posted: 21 Apr 2018 at 8:47pm |
My 2017 HRE 179 (green) came with axle bolted. Ordered lift blocks from FR in Indiana. Can't buy from Lippert direct. Had local tire shop install. The block was like 150, and shipping to Idaho was 25. Local shop charged me 1 hour of labor. In and out in two hours. Also had the bearings repacked before our Sedona trip. Should have done it sooner. Better on our sloped driveway and I never scrapped a single thing on the entire trip.
Thanks Jeff
corpod172
Posted: 22 Apr 2018 at 1:15am |
appears this option is no more on new models
corpod172
Posted: 22 Apr 2018 at 1:27am |
I'm a bit discouraged about this whole situation... I feel the lift is necessary for my needs... going ahead with the Wyoming HRE deal because of it... seems i paid around $2k for a little chunk of rectangular steel tubing welded between the frame and axle... and possibly a difference in the underbelly protection?... not sure... but what's done is done and cant wait...
Posted: 22 Apr 2018 at 7:58am |
Wait a second..."chunk of rectangular steel tubing" sounds an awful lot like there is a welded in riser. The axle is not mounted directly to the frame, so there apparently is some lift in the new design already in the form of a welded riser. That would be an improvement as then there would be no worry about bolts loosening over time. A picture would help. How big is this "chunk of rectangular tubing?"
BTW, on the three posts saying the same things, if you catch it before anyone replies, you do have the option to delete the duplicates under "Post Options." However, after someone replies, the best you can do is edit them. |
Posted: 22 Apr 2018 at 8:31am |
+1 - the riser has to be part of frame and axle bolts to riser, otherwise it would be tough to remove axle. The axles are bolt on.
corpod172
Posted: 22 Apr 2018 at 12:25pm |
here are pics....
https://photos.app.goo.gl/tzs8AjinpMmTMStd2 let me know if it works... first time using google photos |
corpod172
Posted: 22 Apr 2018 at 12:31pm |
roughly 3"x4" maybe?... didn't measure it.
corpod172
Posted: 22 Apr 2018 at 1:06pm |
ok i see now that the axle bracket itself is not welded to the riser as i presumed, but the riser is definitely welded to the frame... I suppose risers could be added in a different way... hmmm.... sorry for the confusion.
