  New Posts New Posts RSS Feed: Sealing/caulking awning and spoiler
Topic ClosedSealing/caulking awning and spoiler
 Post Reply Post Reply Page  <1 34567 8>
Direct Link To This Post Topic: Sealing/caulking awning and spoiler
    Posted: 11 Apr 2018 at 7:06pm
I didn't remove the foam. The hardest part was cleaning off the old Dicor sealant.
It lasted well until it had to go to the factory for the accident repair. The roof was replaced as was the spoiler. I haven't gotten around to getting on the roof to check this spring.
Tibof View Drop Down
Direct Link To This Post Posted: 12 Apr 2018 at 10:08am
So you ran a Dicor bead over the foam?  I am wondering what to do with the foam.
2015 Pod Hood River Edition
2012 Tacoma Crew Cab 4 Liter
Direct Link To This Post Posted: 12 Apr 2018 at 11:41am
I ran a bead and set the foam on that, then made sure the edge was sealed.
Direct Link To This Post Posted: 12 Apr 2018 at 12:19pm
Thanks much Stephen.  Forest River now informs me the the function of the foam is only to seal the screws!  Really poor design. I am going to remove the foam and use something like butyl or Dicor to bed the spoiler.  Screw holes are now identified and can easily be sealed in advance of running in the screws.
Direct Link To This Post Posted: 16 Apr 2018 at 11:11pm
Part of the difficulty in sealing the spoiler is that it is made from what appears to be polyethylene (LDPE) plastic (Like a Walmart storage tub).  The advantage is it’s inexpensive to produce. The downside is that it’s very difficult to find an adhesive or sealant that will adhere to it. Even the adhesive foam tape on a new one peals right off. The sealant used on the LED running lights on the inside of the spoiler appears to be regular automotive RTV gasket making sealant. It rolls right off clean if you rub it with you finger.  No adhesion. 3M 5200 adhesive/sealant will bond to it but is permanent. Truly permanent. 3M 4200 bonds very well and is not permanent. I intend to remove the foam tape, rough the bottom edge of the spoiler and then bed it on a thick bead of 4200, screw it down with stainless screws, and caulk around the outside edge, probably with more 4200. I don’t believe silicone adheres to it.
Direct Link To This Post Posted: 17 Apr 2018 at 8:31am
However from my experience, the lap sealant (not the self-leveling, but the no-run type) seems to adhere quite well. You may wish to use that for bedding and sealing the spoiler.
Direct Link To This Post Posted: 17 Apr 2018 at 10:35am
Thanks Stephen.  I've planned to check the Dicor before investing in the 4200. Though the 4200 is both a sealant and a fairly strong adhesive.  Did you run the lap sealant around the outside edge, also.  Clearly, silicone is unsatisfactory for that purpose.
Direct Link To This Post Posted: 17 Apr 2018 at 5:02pm
If I remember correctly, I did run it to overlap the outside edge a little. It has been a while since I did that and that spoiler got replaced when the roof got repaired so I can't check.
tjdmobile View Drop Down
Direct Link To This Post Posted: 17 Apr 2018 at 5:16pm
This has been an interesting thread.  I had no idea I would need to be looking at resealing anything on our new RPOD for some time to come.
2018 R-Pod 179
2014 Ford F150 XLT Super Crew
Direct Link To This Post Posted: 17 Apr 2018 at 5:26pm
They require maintenance and upkeep, much more so than a vehicle. There is always something that needs a fix, touch up or maintenance. They require care and effort. I see people abuse cars all the time, basically they drive them till they stop or the wheels fall off. I tell folks if you own an RV be prepared to do maintenance and repair. If not - RENT One.
