  New Posts New Posts RSS Feed: water pump
Topic Closedwater pump - Event Date: 17 Jun 2010
Direct Link To This Post Calendar Event: water pump
    Posted: 17 Jun 2010 at 8:17pm
Has anyone had a problem with their water pump stopping when using the hot water?  It works fine with the cold but when you turn on the hot it quits.   Hate to buy a new pump if that isn't it.
TerryM View Drop Down
Direct Link To This Post Posted: 18 Jun 2010 at 4:28am
That is weird!  I have never heard of that before.  If it works when using cold water then the pump is just fine.  There is something else wrong.  Do you get hot water when you are hooked up to a outside water supply and pump turned off?
Terry
Direct Link To This Post Posted: 18 Jun 2010 at 9:09am
Do you have the valve on the hot water line, behind the water heater, opened?  The system gets pressurized on the cold water line so if the hot water valve and the bypass valve are both off the water pump will turn off once the water lines and hot water tank are pressurized.  This is what may be happening:
water tank ----> water pump ----> cold water line to hot water tank ----> hot water tank ----> hot water line out ----> valve (closed) ----> hot water line to faucets ----> faucets
In summer mode the hot water and cold water valves behind the hot water tank should be on (parallel to the pipe), and the bypass valve between the hot and cold pipes should be off (perpendicular to the pipe).
rpodcamper.com View Drop Down
Direct Link To This Post Posted: 18 Jun 2010 at 9:50am
Anything blocking the pipes leading to or from the hot water heater?
Direct Link To This Post Posted: 18 Jun 2010 at 12:14pm
I worked fine when we were in Alabama and were on battery only.  This is just freaky!!
Direct Link To This Post Posted: 18 Jun 2010 at 12:16pm
It will run for a few seconds then the pump shuts off.  Maybe something internally in the pump?
Direct Link To This Post Posted: 19 Jun 2010 at 1:49pm
If it pumps fine when a cold water faucet is open (as you indicated above), its not the pump.  That narrows it down to something on the hot water side.  Check to see if it does this on the sink faucet and the shower faucet.  If only one of them does this you have a blockage in the hot water faucet or somewhere in the line to that faucet.
If it does it on both, check the bypass valves behind the water heater (as I indicated above).
Direct Link To This Post Posted: 19 Jun 2010 at 2:44pm
He hasn't changed anything there since our Alabama trip and we used the pump then.  The shower and kitchen sink on hot stop working.
cane2 View Drop Down
Direct Link To This Post Posted: 19 Jun 2010 at 3:07pm
I vote with Treck. I think it is blockage especially if you did not change anything.
