  New Posts New Posts RSS Feed: 171 - Mod - Dual Gas Tanks
Topic Closed171 - Mod - Dual Gas Tanks
rpodcamper.com View Drop Down
Direct Link To This Post Topic: 171 - Mod - Dual Gas Tanks
    Posted: 29 Apr 2010 at 10:36pm
Why was I thinking that it would be at the top of the bars?  inches off the frame would be ok.
barbanjoe View Drop Down
Direct Link To This Post Posted: 29 Apr 2010 at 3:37pm
it is only one inch higher but I am going to 3/8 " bolts from 1/4" inch so I don't think it will move.
BarbanJoe
010 Rpod 171
02 Jeep 4x4
12 Ram 1500
Direct Link To This Post Posted: 29 Apr 2010 at 3:27pm
Thanks for trying, I have it apart and it will be easier to leave it on and use a 1 inch spacer then to cut the welds so I'll get er done.
BarbanJoe
010 Rpod 171
02 Jeep 4x4
12 Ram 1500
Direct Link To This Post Posted: 29 Apr 2010 at 2:17pm
I just read through 12 pages of search results (which included old archived posts) and couldn't find anything about leaving the original bracket in place.  Lots of mentions of removing it.
Direct Link To This Post Posted: 29 Apr 2010 at 11:22am
I could not find that post about mounting the double over the single BUT if I'm thinking correctly would that not put the 2 tanks pretty high up in the air?  I would be worried about how long is would hold before something snaps.  But that is just my humble thoughts ......
Direct Link To This Post Posted: 29 Apr 2010 at 10:49am
Thanks, I"ll see if I can find the other post.
BarbanJoe
010 Rpod 171
02 Jeep 4x4
12 Ram 1500
Direct Link To This Post Posted: 28 Apr 2010 at 9:48pm
The dealer removed the single tank holder and then installed the dual tank holder.
Sistahs View Drop Down
Direct Link To This Post Posted: 28 Apr 2010 at 7:03pm
My dealer did take off the original tray and put on a new one for the duals. There is an entry on one of these forums showing how to mount the double over the original single. I'll look thru my notebook and see if I can find it. Of course, by the time I find it someone else will probably let you know what entry to look for, but that is fine. We are all about helping each other out.
F150/R-pod171
Direct Link To This Post Posted: 28 Apr 2010 at 6:51pm
Just curious, did the dealer remove the existing tank fixture or put the dual pad over it?
 I have the parts to do it but the existing frame is welded on, I am thinking of using spacers.
BarbanJoe
010 Rpod 171
02 Jeep 4x4
12 Ram 1500
TerryM View Drop Down
Direct Link To This Post Posted: 13 Apr 2010 at 5:02pm
They should also be the same age.
Terry
