  New Posts New Posts RSS Feed: WIFI Tow Vehcile setup
Topic ClosedWIFI Tow Vehcile setup
rawest50 View Drop Down
Direct Link To This Post Topic: WIFI Tow Vehcile setup
    Posted: 13 Oct 2017 at 3:05pm
My new tow vehicle is setup as a WIFI Hotspot. I guess that is what it is called. Not too familiar with the terminology. What I am wondering is can I set it up to stay on through the aux switch on the ignition. Right now it goes off in a few minutes. I know it will draw on battery power so I am not sure if that is a good idea if it can be done.
Any suggestions on how I can take advantage of my TV WIFI? It has a range of about 70 feet. Will connect up to 7 ipads, iphones, etc.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Direct Link To This Post Posted: 13 Oct 2017 at 3:48pm
What's it use for the uplink? Presumably you have to add it (the TV) to your cell service? Or does it use something like satellite service for the uplink?
WiFi by itself means nothing. It's really what it depends on for the uplink.
Direct Link To This Post Posted: 13 Oct 2017 at 4:51pm
It uses OnStar Remote link. 3G, 4G, LTE. Is does not say but I assume it is Satellite since the manual refers to satellite radio.
2017.5 RPod 179
2 Weiner dogs
Direct Link To This Post Posted: 13 Oct 2017 at 4:56pm
If it's a Colorado, mine is the same.
That's the key. "3G, 4G, LTE" says it is using a cellular connection. It will use whatever data connection your OnStar remote link can use. Wonder what data charges there would be? It should be pointed out (in case it's not obvious) that if you are in a "no cell zone", there will be no WiFi either.
Direct Link To This Post Posted: 13 Oct 2017 at 4:59pm
As I recall, we decided not to use ours and it was related to cost.
Direct Link To This Post Posted: 13 Oct 2017 at 6:41pm
I can get unlimited data for $20 a month.
2017.5 RPod 179
2 Weiner dogs
Direct Link To This Post Posted: 13 Oct 2017 at 7:04pm
Go for it.
Direct Link To This Post Posted: 13 Oct 2017 at 7:14pm
It is through my truck. How can I keep my truck WIFI on without the engine running? If my truck is running I have WIFI.   If on aux it goes off after a few minutes.
2017.5 RPod 179
2 Weiner dogs
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 13 Oct 2017 at 7:55pm
Check the owner's manual?
