WIFI Tow Vehcile setup
URL: http://www.rpod-owners.com/forum_posts.asp?TID=10796
Printed Date: 30 Jun 2025 at 1:57am
Topic: WIFI Tow Vehcile setup
Posted By: rawest50
Subject: WIFI Tow Vehcile setup
Date Posted: 13 Oct 2017 at 3:05pm
My new tow vehicle is setup as a WIFI Hotspot. I guess that is what it is called. Not too familiar with the terminology. What I am wondering is can I set it up to stay on through the aux switch on the ignition. Right now it goes off in a few minutes. I know it will draw on battery power so I am not sure if that is a good idea if it can be done.
Any suggestions on how I can take advantage of my TV WIFI? It has a range of about 70 feet. Will connect up to 7 ipads, iphones, etc.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Posted By: GlueGuy
Date Posted: 13 Oct 2017 at 3:48pm
What's it use for the uplink? Presumably you have to add it (the TV) to your cell service? Or does it use something like satellite service for the uplink?
WiFi by itself means nothing. It's really what it depends on for the uplink.
Posted By: rawest50
Date Posted: 13 Oct 2017 at 4:51pm
It uses OnStar Remote link. 3G, 4G, LTE. Is does not say but I assume it is Satellite since the manual refers to satellite radio.
2017.5 RPod 179
2 Weiner dogs
Posted By: mcarter
Date Posted: 13 Oct 2017 at 4:56pm
If it's a Colorado, mine is the same.
Posted By: GlueGuy
That's the key. "3G, 4G, LTE" says it is using a cellular connection. It will use whatever data connection your OnStar remote link can use. Wonder what data charges there would be? It should be pointed out (in case it's not obvious) that if you are in a "no cell zone", there will be no WiFi either.
Posted By: mcarter
Date Posted: 13 Oct 2017 at 4:59pm
As I recall, we decided not to use ours and it was related to cost.
Posted By: rawest50
Date Posted: 13 Oct 2017 at 6:41pm
I can get unlimited data for $20 a month.
2017.5 RPod 179
2 Weiner dogs
Posted By: mcarter
Date Posted: 13 Oct 2017 at 7:04pm
Go for it.
Posted By: rawest50
Date Posted: 13 Oct 2017 at 7:14pm
It is through my truck. How can I keep my truck WIFI on without the engine running? If my truck is running I have WIFI.   If on aux it goes off after a few minutes.
2017.5 RPod 179
2 Weiner dogs
Posted By: Tars Tarkas
Date Posted: 13 Oct 2017 at 7:55pm
Check the owner's manual?
TT
FJ Cruiser
Posted By: rawest50
Date Posted: 13 Oct 2017 at 9:06pm
Check the owner's manual?TT
Owners manual does not address keeping the WIFI available. Think of it this. You get out of your vehicle. Lock the doors. Lights go off. So does the WIFI. Trucks electrical power shuts off. How can I keep the power to the whatever that powers the WIFI. That is why I said the aux on the egnition keep the power to the WIFI, radio, etc.
2017.5 RPod 179
2 Weiner dogs
Posted By: clickscrazy
Date Posted: 14 Oct 2017 at 7:29am
Why not use your phone data that you are already paying for, and just set it to be a hot spot?
2018 R-Pod 171
2014 VW Touareg TDI
Date Posted: 14 Oct 2017 at 10:38am
Yeah, I use my phone as a mobile hot spot, but if your truck gives you unlimited data for $20, that's a good deal.  Depending on the speed they provide.
Leave the truck key in the on position (but not running), use another set of keys to lock the door.
Google might have a better idea.
TT
FJ Cruiser
Posted By: GlueGuy
Date Posted: 14 Oct 2017 at 10:51am
For crying out loud. You're camping. Turn the electronic gadgets off! Disapprove
Posted By: Danielw1
Date Posted: 14 Oct 2017 at 12:53pm
This question could be answered easier in a forum related to your vehicle. I have an f150 and the f150forum.net has answered any question you can think of relating to the truck.
Posted By: rawest50
Date Posted: 14 Oct 2017 at 6:11pm
Sorry if I have to work sometimes. Now a millionaire.
2017.5 RPod 179
2 Weiner dogs
Posted By: rawest50
Date Posted: 14 Oct 2017 at 6:12pm
Why do folks like to tell other folks how to live? To much crap of folks running down others enjoyment.
2017.5 RPod 179
2 Weiner dogs
Posted By: mcarter
Date Posted: 14 Oct 2017 at 6:20pm
I Googled it just to see if I could make a constructive comment. I know my wife elected to not pay the 20 or 200 for a years use, I'm sure reason it stops when truck is not powered is to conserve batt, but honestly not sure. Lot of comments on service and reviews on the interweb. Nothing that addresses your issue. I personally don't use mine, but certainly doesn't make you wrong. If you do find some answers let me know I would be interested.
Date Posted: 14 Oct 2017 at 7:04pm
I can't speak for GlueGuy, but I sure thought he was joking...
Other comments about looking elsewhere for the answer to your question are spot on.  Certainly no harm in asking here but this, obviously, isn't a forum on F150s or WiFi connectivity.
TT
FJ Cruiser
Posted By: TheBum
Date Posted: 16 Oct 2017 at 12:32pm
You may be able to do what I did with one of the accessory outlets in our Highlander: use a fuse tap and wire the Wifi circuit into an always-on fuse socket.
Posted By: GlueGuy
Date Posted: 16 Oct 2017 at 1:20pm
TT
Jokes sometimes don't translate in text. I'm kind of a sarcastic guy, and sometimes that just doesn't work through the interwebs.
Posted By: rawest50
Date Posted: 17 Oct 2017 at 8:20am
No problem.
2017.5 RPod 179
2 Weiner dogs
Posted By: mcarter
Date Posted: 17 Oct 2017 at 6:15pm
rawest50, everything I have looked at says the WIFI is enabled when the truck is running or in the ACC mode, nothing more. I recall the dealership giving us a tour when we bought the truck and the WIFI was covered. Best I could do.
Posted By: rawest50
Date Posted: 18 Oct 2017 at 3:21pm
Thanks a lot. I will try and see what it does. I was thinking I was listening to the radio and after a few minutes it went off but it might not have been in the ACC mode.
2017.5 RPod 179
2 Weiner dogs
Posted By: GlueGuy
Date Posted: 18 Oct 2017 at 4:01pm
Our F-150 will run things in ACC mode for 15-20 minutes or so, then shuts down. You can change the timeout if you wish.
Posted By: mcarter
Date Posted: 18 Oct 2017 at 4:34pm
Rawest50,
My radio is on a time delay not associated with ACC, when truck is off and I haven't opened a door. There is a point where truck shuts down from inactivity, if on ACC it stays on. If there is a place to adjust that time delay I haven't found it.
