P&M
Topic: 171 - Mod - Curtains Posted: 16 Oct 2013 at 10:25am |
Originally posted by TrinityTurret
(I can't seem to find the appropriate post to ask this question on...hope this is ok).
Our brand-new 171 curtains over the main queen bed (the rear of the 171) were not installed very well. They used screws larger than the aluminum tracks, and when they screwed them in, the screws bent & warped the curtain track. As a result, the curtains won't pull past the spots in the track that are messed up.
Is this a 'typical issue', or should I contact the dealer?
Ours are tricky and stick a bit, but they do open/close all the way. If your's won't then I would say yes, contact the dealer and ask them to fix it.
P & M ... and Comet too!
2012 171 -- The Monkey Pod
2018 Ram 2500
TrinityTurret
Posted: 15 Oct 2013 at 10:10pm |
There's only one way...
Posted: 28 Sep 2011 at 2:52pm |
Ours are the same - a pocket across the top and slid the rod all the way through. I didn't alter the valence at all and the rod stays up just fine with friction.
cgarb
Posted: 28 Sep 2011 at 2:34pm |
They look great. I'll have to give it a try! Thanks for the photos.
Carol
177 HRE rpod
2014 Honda Pilot
Posted: 28 Sep 2011 at 1:50pm |
Originally posted by cgarb
We have taken several trips in our HR rpod now and have the same issue with the blinds over the bed. I'm going to do curtains after reading all the posts. When you used the tension rod, did you just make a pocket in the curtain and slide the whole thing, or use tabs or rings?
She just sewed a pocket/channel in the top.. I had to remove the entire valance to get the blinds out, then reinstall the valance. Curtain is held in with a tension rod mounted in the valance.
cgarb
Posted: 28 Sep 2011 at 1:21pm |
Carol
177 HRE rpod
2014 Honda Pilot
yizit
Posted: 29 Dec 2009 at 9:50pm |
You can buy magnetic strips with a sticky back. I'll have to look into that.
Former owner of 2009 172
Darlene & Jim, Ewok our Lhasa
Posted: 19 Dec 2009 at 9:25pm |
They are aluminum, which is why I was going to add magnets (or maybe just strips of steel) to the frames.
Retired Roxy
Posted: 19 Dec 2009 at 7:12pm |
aluminum or not aluminum, that is the question.
Retired Roxy and Cody (4 legged friend)
travelin' in a 172
yizit
Posted: 19 Dec 2009 at 12:09am |
I'm going to look into that magnet idea for the back window. I picked up some really strong magnets our shower curtain at home. They should be able to hold up fabric. I'm even wondering if they will stick to the metal framing around the window. Oh if only Rbug wasn't buried in snow right now.... Snow, Snow go away, why can't spring be here today?
