Author | |||
![]() Posted: 26 Mar 2017 at 11:44am |
I prefer ethyl alcohol, but not for the pod.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3346 |
Charlie, I am sure it was the former! Old is 90+ isn't it?
You're absolutely right! I knew better but I guess I was asleep......or getting old. |
Headed there tomorrow. Right now catching up on "Forensics File", they get rid of folks with antifreeze:)
Shazza ![]() Newbie ![]() ![]() Joined: 25 Mar 2017 Location: North Carolina Online Status: Offline Posts: 8 |
Subzilla is right... Picked up four gallons a buck a piece and it was definitely for rv use. Thanks the tip.
John & Shaz
2016 Rpod 179 2014 Ram 1500 |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6429 |
Please make sure it is NOT ethylene glycol based. ethylene glycol is poisonous! Use ethylene glycol products in your tow vehicle's radiator, not your drinking water system. The one you want is propylene glycol. I'm sure that is what you meant. |
Make sure it's ethylene glycol based, not alcohol. The alcohol based compounds are cheaper but can attack seals and evaporate faster. |
Good to know. At the rate I use rv antifreeze for my pod it takes 8 years to go through 1 gallon. I use compressed air to blow out my lines, takes less than 1 minute and then use 1 pint for the 3 traps (sink, sink in shower, shower trap).
Subzilla ![]() Senior Member ![]() ![]() Joined: 23 Jan 2017 Location: Concord, NC Online Status: Offline Posts: 302 |
Winterizing antifreeze on sale at Wal-Mart $1 a gallon. Normally $3 plus. It was $2 last week so I stocked up then....was tempted to buy more.
Mark
Concord, NC 2017 RP 179 "Podzilla" 2011 Silverado 1500 4X4 |
