  New Posts New Posts RSS Feed: Carbon monoxide detector problem
Topic ClosedCarbon monoxide detector problem
Direct Link To This Post Topic: Carbon monoxide detector problem
    Posted: 08 Jan 2017 at 9:42pm
As mentioned, make sure it isn't a low voltage alarm.  The LP alarm needs a decent voltage to work properly which is why they alarm if the voltage is too low.
Direct Link To This Post Posted: 05 Jan 2017 at 8:43pm
We replaced ours for the same reason this spring.  At least we got 5 years of use before it bit the bullet.
Direct Link To This Post Posted: 05 Jan 2017 at 8:34pm
We had once go a month after we bought our 2015 179. Real easy to replace them.
Direct Link To This Post Posted: 05 Jan 2017 at 8:00pm
They do go bad, they also alarm on a low battery.
rda54 View Drop Down
Direct Link To This Post Posted: 05 Jan 2017 at 7:57pm
You need to replace it they do that after a few years.
Ronald & Lonna
2014 178
2016 Chevy 1500
Nowakgolden View Drop Down
Direct Link To This Post Posted: 05 Jan 2017 at 7:53pm
Anyone have any problems with the carbon monoxide detector? Ours kept going off for no reason. It would stop when we reset it and start again in two hours. The gas was shut off.
Sue
