StonyRiverDave
Topic: Theory on failed Power Converters & possible fix Posted: 10 Sep 2018 at 10:17pm |
I just had a converter failure in the middle of a 6 week trip. On disassembly inspection, I found that the resistor R1 had "fallen off" the circuit board. So I think that the discussions on vibration issues are valid. We also had the read walls bread free from the platform on this trip and needed repairs. The excellent repair by ArrKan RV in Edmonton found just a few screws were holding the back together and were too short or broken off. Trans Canada 16 is quite a bouncy 4 lane.
2017 R-Pod 178
2014 Nissan Pathfinder SL 4WD
Posted: 30 Sep 2016 at 7:38pm |
Originally posted by ChetC
Actually, on the newer AC units like those in the 180, 12v is required for the digital AC thermostat and the AC will not function without it. I learned that the hard way when the first converter went. |
I assumed that was supplied by the A/C itself, like home systems. Learned something today.
rpodnewbies
Posted: 30 Sep 2016 at 12:08am |
Yes that was the first thing we checked was the breakers!
Randy & Sandra
Empty nesters
R180/2017
rpodnewbies
Posted: 30 Sep 2016 at 12:05am |
Thanks Chet!I talked to a service guy today and he said it was probably a bad converter! We are taking it to be fixed! We aren't mechanically gifted to do it ourselves but you gave great directions! Thanks again!
Rpodnewbies
Randy & Sandra
Empty nesters
R180/2017
ChetC
Posted: 29 Sep 2016 at 11:15pm |
12 volt power isn't needed for the A/C, so that would lead me to think a circuit breaker or two is tripped, as suggested above.We've seen very few converter issues on this board, even with pods that have 20,000+ miles on them (like ours did). It is possible you just ended up on the low end of the bell curve with two bad converters in a row. |
It's possible I was unlucky in the converter department but the coincidence of the mileage being very close the same both times is highly suspicious to me, which led to my investigation and theory. I'm not claiming this is a guaranteed issue or fix, I'm just sharing my experience.
Former 2017 rPod 180 owner
Now in a 2019 Little Guy MAX
Full timer who logs more than 35,000 miles per year.
Posted: 29 Sep 2016 at 8:22pm |
ChetC
Posted: 29 Sep 2016 at 6:28pm |
Originally posted by rpodnewbies
We are having electrical issues too with our 2016 Rpod 180. The outlets work but the fridge, A/C, slide, lights and radio won't work. Is this something like what your issues were?? I'm not sure where the tray is that you are talking about.
A bad converter, or more precisely a dead battery, would most definitely cause those issues. All of those items require battery power to operate. The fridge uses battery power to run its "processor", even if electric or propane is selected. The AC requires battery power for the thermostat, if it doesn't have sufficient power the AC sounds like it is struggling to start or will not start. The lights, slide and radio are completely run off of the battery. If your converter is bad the battery will not charge and all of those will fail once the battery is drained.The converter "tray", as I called it, is located behind the main panel. If you open the panel to access the breakers, you will see two Phillips head screws, one on each side. Remove those and the cover panel will tip out at the top. Once it's tipped out, lift straight up to remove the cover. The comverter is located on the very bottom, on a tray held in place with two more Phillips head screws. Make sure all power is off (battery too) before messing with the converter or you may get shocked.
You can see if your converter is charging or not by simply pressing the Battery button on your monitor panel. While the tank level lights are hit and miss, depending on a variety of factors, the battery lights should always be accurate. If all four lights, or more precisely the top most light, is lit then the converter is charging. If it's not, then the converter has pooped out. I always, always, always hit the battery button every time I plug in to a new location, just to verify that the converter is charging. If it is functioning properly, it will always light the top most light when you are plugged into shore power regardless of whether or not the battery is good. That light is lit by the charging function of the converter, not the level of the battery. If the top most light is not lit, then you have an issue with the converter.
ChetC
Posted: 29 Sep 2016 at 6:14pm |
Whoops, I meant to quote not reply...
See below.
TheBum
Posted: 29 Sep 2016 at 11:47am |
The converter only converts 120VAC to 12VDC. It has nothing to do with the other 120VAC equipment.
Have you checked the breaker panel to make sure one or more breakers haven't tripped?
Posted: 29 Sep 2016 at 8:19am |
The WFCO 8955 converter/charger has been in use for a decade or more, used in millions of RV's. Other makes are also seeing an uptick in dead ones, and the problem has been traced to a bad batch of transistors.
