  New Posts New Posts RSS Feed: Hot water heater thermostat
Topic ClosedHot water heater thermostat
Direct Link To This Post Topic: Hot water heater thermostat
    Posted: 02 Dec 2015 at 10:02pm
Originally posted by JandL
My Suburban water heater came standard with a 130 Degree Thermostat switch, it is not adjustable. They make a 120 and 140 degree. You only have 6 gallons so if it to low a temp you could use all the hot water up
+1 on keeping it at 130 so you have more usable hot water.  6 gallons is barely enough even with Navy showers.
The risk of scalding goes up a lot at 140 degrees so I don't recommend going there (not that the OP will).  I just installed a new WH in my home a few weeks ago and it has a digital interface where I can set the temperature with a few button pushes, up to 160 I believe.  It defaulted to 120 and I set it for 130.
Just below 120 you start flirting with Legionnaire's which is partly why I prefer 130.
RoadToad View Drop Down
Direct Link To This Post Posted: 02 Dec 2015 at 12:30am
OK- Thanx guys.  Tomorrow I was going to tear up my bed to get to the RP-179 electric water heater and try to adjust the heater- glad you informed me.  I got plenty of other stuff to do.  RoadToad
JandL View Drop Down
Direct Link To This Post Posted: 01 Dec 2015 at 8:43am
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
CharlieM View Drop Down
Direct Link To This Post Posted: 01 Dec 2015 at 8:35am
The thermostats are not adjustable. There are alternate thermostats available, but only +/-10 degress from the original 130F.
Direct Link To This Post Posted: 01 Dec 2015 at 6:32am
Electric hot water heater way too hot. Where is thermstc adjustment for this. I'm guessing atop hot water tank?
RoadToad
2015 RP179
