  New Posts New Posts RSS Feed: aluminum framework
Topic Closedaluminum framework
Direct Link To This Post Topic: aluminum framework
    Posted: 30 Oct 2015 at 4:50pm
The front/back/top is all wood, so you should be able to use a standard stud finder.
sailor323 View Drop Down
Direct Link To This Post Posted: 30 Oct 2015 at 2:19pm
Thanks for this tip.  I will be attaching solar panel(s) to the roof and would like to tap into the framework somehow.
kymooses View Drop Down
Direct Link To This Post Posted: 30 Oct 2015 at 9:49am
Originally posted by rayman
Some time ago someone asked about finding the aluminum studs inside the r pods.I have noticed that on cool mornings when there is a heavy dew or frost you are easily able to see where all the framework is from outside the pod.You could translate that to the inside and determine where to place fasteners to attach heavier items if need be.maybe this will help someone.
Aye, I've sketched out a rough drawing of my entire Pod from watching it on cool mornings just in case I ever need it for anything or just reference.
rayman View Drop Down
Direct Link To This Post Posted: 30 Oct 2015 at 8:09am
ky.froggers
