  New Posts New Posts RSS Feed: Black water flush system
Topic ClosedBlack water flush system
johnmaci View Drop Down
Direct Link To This Post Topic: Black water flush system
    Posted: 25 Oct 2015 at 7:53am
A little expensive, but this works well too:
http://tweetys.com/flush-king-holding-tank-rinser.aspx?gclid=CLO-mO7H3cgCFUMWHwod_MEAdA
kymooses View Drop Down
Direct Link To This Post Posted: 25 Oct 2015 at 12:18am
Originally posted by im20agn
We have one on our 179. When I tried to use it water comes out of the bottom of the trailer the dealer told us it was a bad J valve and replaced but it still does the same thing so we clean out the system with a hose in the toilet.
Mine has been worked on before and still leaks like that also.  I've learned to not use it, never wanted to take the extra time at the dump station anyways.
Couple things it could be, the valve there does have to be positioned so that it remains vertical.
My issue this time is a the hose has a pretty good bend in it that I think has popped the clamp off the valve.
Probably not something I'll ever bother fixing.
Direct Link To This Post Posted: 24 Oct 2015 at 2:40pm
If yours is under warranty I would take it back again.  No reason to leave it like that.
im20agn View Drop Down
Direct Link To This Post Posted: 23 Oct 2015 at 1:13pm
cdremy View Drop Down
Direct Link To This Post Posted: 23 Oct 2015 at 1:08pm
Thanks for your replies. Ordered a wand on Amazon.
JohnBG View Drop Down
Direct Link To This Post Posted: 20 Oct 2015 at 12:46pm
The black tank flush is standard on the newer pods, not sure what year they started including them.
My 2010 doesn't have the built-in flush system, so I use a toilet stick with a hose at the dump station.
2010 R-Pod RP-171
2010 Honda Ridgeline TV
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 19 Oct 2015 at 7:17pm
Our 2011 177 came from FR with that.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 19 Oct 2015 at 6:37pm
My friends travel trailer has a inlet where he can hook up a hose to flush out the black water. Does anyone know of a after market connection that will do the same thing.
