Camper Bob ![]() podders Helping podders - pHp ![]() Joined: 26 Sep 2011 Location: Portland Oregon Online Status: Offline Posts: 913 |
![]() Posted: 11 Sep 2015 at 10:48am |
Thanks Dan. Will set aside some time next week and conduct the exam. We just finished our 5th and last trip of the season. Going to print out your excellent list to winterize and prepare the Pod for winter. Next week it gets a bath and a waxing, and then cover for the winter. Thanks again for the help. Safe Travels.
Camper Bob and Camper Sue
First test is to disconnect it for at least 3 hours. Look up the specs for your battery to find out the resting voltage. For most lead acid batteries it is right around 12.7 but those higher end batts sometimes are different. See how close your battery is to the spec. It should be very close. If not it may be shorted out internally, or sulphated badly so it won't accept a charge.
Next is a load test. Hook up the battery with the pod unplugged from AC power. If you still have incandescent bulbs in your fixtures turn on 8-9 bulbs (not fixtures - many of them have 2 bulbs). That is about a 10-11 amp load. If you have LED lights an alternative is to turn the fridge on DC mode, if the fridge is warm inside and the pod's interior is warm (not the middle of winter), and leave the door open. That is a 10-11 amp load. Leave the lights or fridge on for one hour, then turn it all off and disconnect the battery. Measure the voltage. Let it rest again for at least 3 hours. Measure the voltage again. Go to the link below and scroll 2/3 of the way down to the colored chart of voltages. Your first measurement (right after disconnecting the battery) should be somewhere in the green. The 2nd one should be around the 80-90% marks. If either/both are well below then it is probably sulphated. It may show a good voltage in the first test (the very first test - resting voltage) but there is little lead plate left to accept a charge so the voltage will crash quickly with the 2nd and 3rd measurements in this test. http://www.solar-electric.com/deep-cycle-battery-faq.html |
When we took delivery of our Rpod, I had the dealer substitute an Optima group 27 AGM battery. It is now 3 years later and it has always been connected to house power and trickle charging when we aren't camping. I was wondering how to test the battery to see what condition it is in? It is a sealed no maintenance battery with Absorbent Glass Matt technology. Any suggestions from the battery guru's?
