  New Posts New Posts RSS Feed: Cannot run A/C on 15amp Circuit
Topic ClosedCannot run A/C on 15amp Circuit
Direct Link To This Post Topic: Cannot run A/C on 15amp Circuit
    Posted: 15 Jun 2015 at 3:41pm
That would explain it.
Podster View Drop Down
Direct Link To This Post Posted: 15 Jun 2015 at 6:55am
Definitely a 13.5 here.
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 14 Jun 2015 at 8:29pm
Definitely odd, I measured mine at 1000 watts on low.  Maybe mine was 11k btu and yours is 13.5?
Direct Link To This Post Posted: 14 Jun 2015 at 6:42am
I tried again last night...14.32 amps at 1629 watts and climbing. No go here.
Cliff & Raelynn
Ranger 4.0/178
Pooterpod View Drop Down
Direct Link To This Post Posted: 13 Jun 2015 at 10:27pm
My AC would blow the circuit breaker in the garage until I swapped to a larger wired ,shorter extension cord to the outlet. No problem now. 15 amp circuit breaker.
Direct Link To This Post Posted: 13 Jun 2015 at 5:29pm
I checked the idle draw right after shutting down. .5 amps. Will try again later tonight. To darn hot out there right now.
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 13 Jun 2015 at 5:16pm
Are you sure the converter wasn't running, etc? Once running, I have never seen one pulling more than 11A..
And honestly.. I would just put in a 30A circuit. Same space in the box.. (that's generally the issue)
Direct Link To This Post Posted: 13 Jun 2015 at 4:56pm
Just wanted to post my experience today with trying to run the A/C unit on a home 15amp circuit (nothing else running on it during the test). Using good heavy gauge 30amp feed line, I plugged in and it started and ran good. I was watching it closely and after 10 minutes noticed the plug in the garage was starting to heat so I shut it down to take a measurement.
It was pulling 15.3 amps...over 1700 watts so my conclusion is, at least for me...
A dedicated 20amp circuit is required to run my POD A/C properly.
Some may already know this, but I have seen some chatter here and there about a 15amp circuit being able to handle it. I don't think so, at least not for me. Smile
I have everything needed to run an additional dedicated 20amp circuit, guess I better get it done.
Cliff & Raelynn
Ranger 4.0/178
