  New Posts New Posts RSS Feed: Tip out stop block?
Topic ClosedTip out stop block? - Event Date: 11 Jun 2015
eightdaves View Drop Down
Direct Link To This Post Calendar Event: Tip out stop block?
    Posted: 12 Jun 2015 at 12:39am
The correct term would be slide-out. The model No. RP-177. The bracket fell off at the bottom of the slide-out. The piece is shaped like a c with a set screw to clamp to something. Fit on the rail bracket so I think it went there. Just not sure. Perhaps a picture is worth more than my description indicates. Thank you for your suggestion.
Direct Link To This Post Posted: 11 Jun 2015 at 9:13pm
I'm guessing you mean the slide-out?  Probably a tent model?
Direct Link To This Post Posted: 11 Jun 2015 at 8:08pm
What model pod do you have?
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 11 Jun 2015 at 8:02pm
I don't know what a tip out is??? A picture of the clamp would be helpful.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
Direct Link To This Post Posted: 11 Jun 2015 at 7:40pm
Pulling in  the tip-out recently a clamp device fell on the floor. One of those pieces that fall and you are left wondering where it went. It appears to be near the track rail that the tip-out rides on. The piece is the shape of a long c clamp with a set screw to secure it to something. I moved the tip out in and out. There appears to be no problem so I anchored it to the rail. I am not sure if I put it back in the correct spot. I am concerned about my deduction of the problem, any experiences with this mystery part would be helpful.
Thanks so much for being out there... Dave and Kristin
