  New Posts New Posts RSS Feed: Battery Issues
Topic ClosedBattery Issues
CharlieM View Drop Down
Direct Link To This Post Topic: Battery Issues
    Posted: 14 Mar 2016 at 10:31pm
Unless you disconnect the battery while the pod is plugged in, then the loose positive connection could short to the frame.  My personal reason for going with positive.
Doug, I'm missing your point here. The possibility of the positive lead contacting the frame when the Pod is plugged in was my weak concession to disconnecting the negative. Otherwise I agree positive is per convention.
Direct Link To This Post Posted: 14 Mar 2016 at 10:07pm
However, if a loose negative contacted the frame, there would be no issues whatsoever. That is another reason for going with negative.
Direct Link To This Post Posted: 14 Mar 2016 at 10:01pm
Direct Link To This Post Posted: 14 Mar 2016 at 8:56am
If you store without electricity you should disconnect the battery. It's only necessary to disconnect one side. Simply removing the lead with a wrench works just fine and the price is right. IF you ever might plug in the Pod before reconnecting the battery a weak argument can be made to disconnect the negative side, otherwise disconnecting the positive is customary. That said, it really makes little difference.
Direct Link To This Post Posted: 14 Mar 2016 at 8:53am
Originally posted by OnTheRoad6
Someone please help this ignorant (!) trailer newbie!
I guess, based on what I am reading, that I should disconnect the battery on my Pod as it is stored where I don't have electricity. But I've also read several opinions for disconnect -- is it negative first, positive second, or positive first, negative second, or just positive or just negative? Smile
I won't do the switch option now after spending a ton of money to get the breaking system installed. I can't do it myself so have to pay big bucks for everything -- this RV thing gets expensive! It's okay and totally worth itSmile
Thanks for any help you can give me.
You only need to disconnect one lead. Disconnect which ever one you want. It's a Ford-Chevy, Blondes-Brunettes argument about which is better. I do the positive.
OnTheRoad6 View Drop Down
Direct Link To This Post Posted: 14 Mar 2016 at 8:20am
Direct Link To This Post Posted: 22 Jun 2015 at 8:25pm
The question that needs to be asked in this discussion. What came first; the chicken or the egg?
sailor323 View Drop Down
Direct Link To This Post Posted: 22 Jun 2015 at 8:06pm
If the switch is between the negative battery post and the ground, which it pretty much has to be, then there is no danger of spark from a positive wire.  There would be no negative to the ground.  Sparks happen when the circuit is closed from positive to negative (not to ground).
TT
Good point, TT  and in fact explains why it doesn't really matter which side is switched.
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 22 Jun 2015 at 7:58pm
Originally posted by sailor323
Putting the switch on the positive side is the safer choice.  The reason is simple.  If there is some kind of grounding of the positive wire between the battery and the pod,  there is a significant risk of fire.  Disconnecting the positive side eliminates that risk, while switching the negative side does not.  Switching the negative side leaves the positive wire hot.  A major no-no in electricity.  Essentially, if you put the switch on the negative side, you have not disconnected the battery from the pod.
TT
FJ Cruiser
Direct Link To This Post Posted: 22 Jun 2015 at 6:29pm
