  New Posts New Posts RSS Feed: refrig/oven elecrical connection
Topic Closedrefrig/oven elecrical connection
Direct Link To This Post Topic: refrig/oven elecrical connection
    Posted: 23 Mar 2015 at 4:29pm
Something else to check inside the pod, for any future problem, is the GFCI outlet.  Several things, including the fridge, are usually on that same circuit.
john in idaho View Drop Down
Direct Link To This Post Posted: 23 Mar 2015 at 12:22pm
I guess the next question is 'WHAT TRIPPED THE BREAKER"?  Is the trailer plugged in to a 15 amp circuit?   That may not be enough if you had everything on.  I think the reason the lights were working is that they switched to battery when the breaker tripped.
Direct Link To This Post Posted: 23 Mar 2015 at 12:17pm
Some breakers, esp the little skinny ones, are hard to see when it is tripped.  And one has to flip the breaker completely off before resetting it.
Happy Tripping View Drop Down
Direct Link To This Post Posted: 23 Mar 2015 at 11:42am
Hello. I did a quick 'search' for this but only got confused, unfortunately I am ignorant about electricity. - In preparation for a trip across country, I decided to bake a pie. I am on house electricity.
I had a heater hooked up to warm the rpod. Now, it looks like a breaker flipped. The heater is now inoperable, the oven is warm but quit 'preheating' and is now inoperable, and the refrigerator, which was switched 'off' when I started cooking, when I put it on to see if it was operable now just blinks and alarms. The tv seems to be inoperable altho the little red light for the antenna is working.
No breakers have flipped that I can see in the rpod, including the gfci on the outlet. My house breakers look ok except the gfci breaker had tripped and I flipped it back, no change resulted  that I can see. I checked the electrical cord house connection and it seems fine.
On searching previous topics, it seems the refrig, oven and maybe tv should be on separate circuits, and why can I not find a flipped breaker?
The rpod lights, radio, etc seem to be working fine.
Of course, I have probably made some stupid beginners mistake so any help is very much appreciated.
*** Since writing this, I went out and disconnected the battery and now have no electricity. ***
CANCEL THE EMERGENCY - My wife came home and told me you have to REALLY  flip the house circuit breaker, she did and now we are back, sorta, to normal.
