  New Posts New Posts RSS Feed: AF DRIP
Topic ClosedAF DRIP
wildfire305 View Drop Down
Direct Link To This Post Topic: AF DRIP
    Posted: 15 Jan 2015 at 12:19am
Open - I'm a plumber. RV Antifreeze will freeze/slush at around 10 degrees, but it will not expand until -50. I use it in my backflow test gauges during the winter. Open valves allow the system to breath, expand and contract.
2005 Dodge Durango 4.7 V8
OLD Tow Vehicle 2004 Honda Odyssey
2015 RP179 "73b"
OLD 2005 Viking Saga 2480ST popup
Luv2Q View Drop Down
Direct Link To This Post Posted: 03 Jan 2015 at 10:24pm
Originally posted by Podster
Open! But I do the drain and blow out with pink stuff in the traps only.
Ditto here.  Same mild winters as Podster.  (Slight OT side note: My father-in-law lived several years just outside Madison, WI and only drained + AF in the traps.  Never a prob.)
John & Teri
Tundra 5.7L V8 / RP 180
Podster View Drop Down
Direct Link To This Post Posted: 03 Jan 2015 at 6:08pm
Cliff & Raelynn
Ranger 4.0/178
hogone View Drop Down
Direct Link To This Post Posted: 03 Jan 2015 at 11:50am
do most of you leave faucets open or closed?  hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 03 Jan 2015 at 11:37am
I don't know about the drips with the faucets closed.  No help there, but I always thought you should leave faucets open to allow for any expansion.  I mean, it shouldn't happen anyway with antifreeze but if there is some water in the pipes and it freezes, an open escape for expansion is less likely to cause damage than a closed valve.
TT
FJ Cruiser
dsmiths View Drop Down
Direct Link To This Post Posted: 03 Jan 2015 at 11:09am
I get the same thing, I think its barometric pressure change or temp change, sometimes I open and close faucets to equalize pressure and then they drip for a bit.
Dane and Donna Smith
2011 RP-172
lift kit
Direct Link To This Post Posted: 03 Jan 2015 at 11:07am
I get that every year in the sink and shower and chalk it up to moving the camper around after winterizing it.  There is some antifreeze in the pipe between the valve and the nozzle.  Expansion makes sense, too.
Direct Link To This Post Posted: 03 Jan 2015 at 10:42am
just curious.  haven't been in the pod for a while.  went in today and noticed the kitchen sink had leaked/dripped some anti-freeze out.  knobs are off.  we have had some pretty cold temps.  is this just due to expansion due to up and down temps?  hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
