Page 12> |
![]() Posted: 23 Nov 2016 at 11:15am |
http://www.rpod-owners.com/forum_posts.asp?TID=8136 |
Blue Highways ![]() podders Helping podders - pHp ![]() ![]() Joined: 20 Sep 2016 Location: NC mountains Online Status: Offline Posts: 86 |
Your TV easily outputs through the speakers. Just plug in the typical little double-ended 3.5mm jumper wire from the TV to the Jensen Unit.
Power up the J-unit and set it to "Aux 2", and the sound comes out nicely through your roof speakers using the round volume dial. The little jumper cable that I describe is the same one you'd use to attach a device to your car's aux port, (such when you play music off your smartphone or the earlier I-pod / MP3 players.....) Not sure what is the technical name for this wire, anybody??? We leave this permanently attached to the TV in the Pod. Just be careful that you don't also have the outside speakers on while you're watching your show, or you might get a knock on your door ![]() I also mounted a little remote carrier box to the top of swing-out arm for the TV to hold the remotes, so they never get lost. I mildly modified the mount also to give the TV a slight more down slant... but that's only a temporary fix for now until I figure out the best tilt solution that other Podders have found on Amazon, etc. Finally, I recommend upgrading the stock light-duty white-covered roof speakers. I used Sony Xplod ones with larger magnets, that fit fine in the roof cavity. It's not so much that I planned to "rock the house" (yet) but wanted a fuller, rich sound at low or moderate volume accompanying the video output. I learned the Aux 2 thing earlier from others in our virtual community, so wanted to share this and other considerations with you. |
This is a dealer problem. I can tell you for sure the pods ship from the factory with every bit of paperwork for every appliance in a folder. Seen it. Remote, a/c filters, etc, are usually in that envelope. |
Bama Pod ![]() Groupie ![]() ![]() Joined: 04 Oct 2016 Location: Huntsville AL Online Status: Offline Posts: 89 |
Will the TV play through the sound system? I see output wires from the TV to the sound system and I monkeyed with it a while but with no success.
Bama Pod
Huntsville, AL 2017 Ford F250 2017 Airstream 26U |
Bill-J ![]() Newbie ![]() ![]() Joined: 03 Nov 2016 Location: WA Online Status: Offline Posts: 36 |
I am also looking for the manual for the Jensen JE1914 and I find places that list this model but when I try to download the pdf file it changes to a Jensen JE3914.
Also I never found a remote control for the TV. Did your alls come with one? So have a new R-pod 180RB, no instructions on much of anything. Seems you are suppose to intuit how to use everything. |
When in doubt, don't.
Welcome to the forum! ![]() |
MTNMANLARRY ![]() Newbie ![]() ![]() Joined: 03 Apr 2016 Online Status: Offline Posts: 1 |
Go to the Jensen site and look for the 14 series manual. You will find that they are all in there 2414, 3914, 1914, etc.
rimshot ![]() Newbie ![]() Joined: 15 Feb 2014 Location: California Online Status: Offline Posts: 23 |
Went to menu and it was on "air" did a channel search and bingo. They're all back. Thanks for all the help everyone. Better write this down now....
David and Danette ![]() podders Helping podders - pHp ![]() ![]() Joined: 24 Nov 2009 Online Status: Offline Posts: 1225 |
If you are able to get a channel check to see if antenna is working by turning the antenna amplifier off. If the channel goes off and you get no signal then you know it is working if there is still a picture perhaps the antenna is not working. You can go to the manufactures website and download manuals I had to do that.
Podster ![]() Senior Member ![]() ![]() Joined: 16 Sep 2014 Location: San Antonio Online Status: Offline Posts: 1108 |
In addition to selecting Air or Cable (tuning source), you have to select the correct "input" on the TV, that is the source for the signal you want displayed. In other words if you want to watch a DVD you may have select the input that the DVD player is hooked up to: HDMI1? or HDMI2? or...after tuning and selecting AIR on the menu, go thought the inputs and you should find the correct one when a TV program is displayed.
Cliff & Raelynn
Page 12> |
