  New Posts New Posts RSS Feed: Playing TV thru stereo
Topic ClosedPlaying TV thru stereo
Oliveman View Drop Down
Direct Link To This Post Topic: Playing TV thru stereo
    Posted: 08 Jun 2016 at 2:40pm
Newbee
I Just got a 2016 178. Can you play the TV sound thru the stereo speakers. We used the TV once so far but only got sound from the TV speakers.
2016 R-Pod 178
2015 Pathfinder Platinum AWD
Wife, Child and Dog on adventures
TheBum View Drop Down
Direct Link To This Post Posted: 08 Jun 2016 at 3:08pm
Yes, but you'll have to pull the stereo out of the wall and switch some connections around. On the stereo, the audio output connections for the DVD player need to be moved to the AUX1 (or AUX2) inputs. On the TV, the audio input connections from the DVD need to be moved to the TV audio outputs. Don't change the video (yellow) connections. You will lose the ability to hear DVD sound through the TV, but it will still come out the stereo.
Direct Link To This Post Posted: 08 Jun 2016 at 4:09pm
Thanks, I was wondering why the TV outputs were connected to a wall plate RCA and figured they must continue on to the AUX input but I never pulled out the DVD/Stereo to see how they hooked it up. So I take it the factory setup is for DVD play only thru the speakers and not TV channels? Seems like most consumers would want both?
2016 R-Pod 178
Direct Link To This Post Posted: 08 Jun 2016 at 5:06pm
No, the factory setup does allow for playing back DVD audio through the TV. The mod I suggest takes away that option. You could add another audio cable if you wanted to retain the factory setup and get TV playback through the stereo speakers, but it would require drilling a hole for the extra cable. The method I proposed requires no drilling at all.
Direct Link To This Post Posted: 08 Jun 2016 at 6:05pm
I get it now, The current setup is an output of the DVD and an input to the TV. I need an additional Red White RCA out put from TV to input AUX on Receiver/DVD. Thank You, I will make Mod #13 to R Pod
Mods so far before first trip
#1 New Queen mattress
#2 Reinforced Seating area and Modified storage layout with pantry
#3 Cutting Board over stove
#4 Shelves over dinette
#5 Shelves over Queen
#6 Toilet paper dispenser under sink
#7 Spice rack in kitchen
#8 Solar and Generator
#9 Additional Sewer hose storage
#10 Lots of storage crates in outside storage
#11 Little stuff like mirrors, hooks, hanging storage
#12 12 Volt DC outlet
Still to do
#13 RCA's TV to Receiver
#14 Dual 6 Volt batteries
First Trip planned 6/22-7/4 Eastern Sierras
2016 R-Pod 178
Direct Link To This Post Posted: 08 Jun 2016 at 6:08pm
Exactly, if you want the best of both worlds.
Direct Link To This Post Posted: 08 Jun 2016 at 6:23pm
That is quite a list!
